"no phone" help please!
Hi
I've read some of the reply's regarding pairing of a mobile to an x type with phone capability but i can't work out from my vin number if i should have it or not.
On the Jaguar website when i place in the last 6 digits of my vin number, it gives a list of compatible phones, does this suggest that i should be able to hook up a phone to my car, or does the website do this for all cars?
I'm unsure if i'm buying a parrot system or not as i can't seem to get this to work!
any help appreciated and last 6 characters are J10755 if anyone else can work it out for me!
Link for jaguar bluetooth compatability.... (is this the same thing?)
http://jaguar4.nextgen-technology.co...country=na&n=0
Many thanks
Many thanks
Just because you have the button on the radio unfortunately does not mean you are able to connect a phone to it.... Most likely you do not have the option. I press the button and my phone just works. :-)
That doesn't really give me a definitive answer, is there any way of telling if i do have the system installed for the bluetooth phone?
The website where you enter your 6 digit vin code says that i should be compatible with ........ phones, does everyone get this on the website?
The jaguar Website only checks VIN ranges. It does not check specific VIN's to see if there is a phone module installed.
If you send me the last 6 of your VIN I can check for you.
-David
www.jpamporschejaguarparts.com
-David
If when you push the phone button, you get a screen that says either
no phone or no phone attached, you don't have the blue tooth module, if you did when you push the button you would get a screen that would allow you to but a code in to activate the module at least that is the way it worked on my last 2 x types one with and one without the module both 2005's
You do not have the phone module installed. As far as the radio code, you would normally have to contact your closest dealer, and find out what they will need from you for ownership verification.
-David
-David
