No power to starter
Old Dec 22, 2013 | 07:32 AM
chrissimmons's Avatar
Default No power to starter
Everything was fine then I bumped the kurbstone at some speed catching both front and back wheels.
The car continued to run, but the wipers stopped straight away. When I turned the ignition off I found that the starter motor did not work either.
So .... some electical circuits do work - full-beam for example, but the other circuits do not. I have visibly checked all of the 'small' fuses in both fuse boxes, and all appear fine.
Dont work - Starter, wipers, washer, blower, head-lights,
Do work - full beam, radio, central locking, internal lights, side lights, fog-lights, full-beam, lights-on alarm, horn, windows.
Anyone got any ideas?
Old Dec 22, 2013 | 07:38 AM
jimbov8's Avatar
If you hit the kerb that hard then check the relays also. My money would be on a dislodged ground cable, so worth checking those too.
Hope this helps,
Old Dec 23, 2013 | 12:36 AM
Many thanks for your advice Jim.
I have a mobile mechanic coming today to look at it, and I will pass on your suggestion.
Will let you know how I got on.
Cheers!
Chris
Roger Geirnaert
Oct 12, 2015 01:01 PM
Jahnese Alston
US Northeast
Sep 20, 2015 02:22 PM
Shaggy9212
XJ40 ( XJ81 )
Sep 14, 2015 08:08 PM
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
