Noise in the front. (rt front)
Old Mar 14, 2022 | 02:15 AM
Mr rx-7 tt's Avatar
Default Noise in the front. (rt front)
I have a thumping sound that I can't figure out. I thought it was new tires, rotated same noise. (rt front) Noticed a small amount of transmission fluid in the driveway today...I replaced the fluid 3 months ago.
It almost sounds like a bearing...
Old Mar 17, 2022 | 10:47 PM
Mr rx-7 tt's Avatar
I am going to get the front bearings replaced and I think I may just replace the struts, the strut mounts and bump stops in the front end as well.
Anything else anyone can think of? (Car has 94,000 miles)
Thanks!
Old Mar 18, 2022 | 10:39 AM
RudyF6's Avatar
Swaybar links too.
Old Mar 19, 2022 | 03:24 PM
Mr rx-7 tt's Avatar
2 front struts
2 strut mounts
2 wheel bearings
2 sway bar links
2 bump stops
Anything else?
Old Mar 30, 2022 | 10:28 PM
Mr rx-7 tt's Avatar
The passenger side axle was worn and making the noise.
I went ahead and replaced:
* Both front wheel bearings
* Both front struts
* Both front bump stops
* Both front bellows
* Both strut bearings
* Passenger side axle
* Lower power steering hose
Replaced original serpentine belt and idler.
No movement in the sway bar links (front) I replaced the rears earlier.
I've now done both the front and rear.
Now I need to change the transfer case oil and differential oil. Did the transmission and the car shifts like glass.
Bob S.
May 14, 2016 04:29 PM
Amadauss
25
Apr 29, 2014 03:07 PM
05xtypeee
Feb 7, 2012 04:51 AM
disguay
Oct 20, 2011 12:14 AM
Jaguardoc504
Aug 2, 2011 08:15 AM
