Oil in coolant compression OK
Old Jun 29, 2012 | 02:58 PM
PA Tech's Avatar
Default Oil in coolant compression OK
I am diagnosing a friends Jaguar X-Type 2002 2.5 v6. There is oil in the coolant and a misfire. He claims that the car over heated twice and the coolant level got low. After the 2nd time he says the misfire started. I checked the coolant which is low in the resivour but is very brown. The oil however is not milky. I initially thought it was a head gasket problem so I compression tested all 6 cylinders. They all read within 5 to 10 PSI of each other at approx 180.
Without tearing down any more of the engine I am looking for other possible causes. Any suggestions are appreciated.
Thank you.
Old Jul 2, 2012 | 09:09 AM
PA Tech's Avatar
Any suggestions?
Old Jul 2, 2012 | 10:15 AM
ooootis's Avatar
Try this thread! Starting @ comment 5 may not be the problem but its place to start BEFORE you tear somehting apart.
https://www.jaguarforums.com/forum/x...uper-v8-75945/
bamforp
Aug 14, 2024 05:36 PM
mrplow58
Jan 21, 2024 05:53 AM
Rivguy
Dec 4, 2020 07:55 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
