Oil Light On
Old Dec 22, 2020 | 12:34 AM
foleyaxle's Avatar
Default Oil Light On
To cut a long story short, i've had my 2.0d xtype parked up for 10 days doing nothing while i worked on ball joints and bushes for its MOT.
Now previously if the car was sat for 2 days the battery would drain and i would have to charge it and it would discharge itself after 2 or 3 cranks.
Now after getting the car started again the oil light started coming on ?? previously it's been fine no codes no oil lamp but all of a sudden this has started happening it would remain on, flicker, dim, flicker and then go off and remain off ? oil level is fine, new battery has been installed and so far is no longer draining.
Your help is appreciated.
Old Dec 22, 2020 | 04:59 AM
Roadsider's Avatar
I would check the oil pressure sensor or replace it if it still stays on you would need to get it to a garage to have it checked out dont drive though no oil pressure will total the engine good luck
Old Dec 22, 2020 | 07:52 AM
foleyaxle's Avatar
Now that's interesting took the car out during my lunch break started up fine and the oil light went off as normal and stayed off as normal ?
Old Dec 22, 2020 | 09:18 AM
Roadsider's Avatar
Best keep an eye on it but i would still think about the oil sensor cheers
Old Dec 22, 2020 | 09:46 AM
foleyaxle's Avatar
Thanks i've already got one from euro car parts i will put it aside for now and monitor the situation.
Old Dec 27, 2020 | 05:40 PM
Skander Singh's Avatar
Default Resolved
It was the switch put a new one in and job done.
Old Dec 27, 2020 | 06:18 PM
NBCat's Avatar
How many kilometres/miles are on the vehicle?
Has the oil pressure been checked using an external gauge to verify it is the switch?
jmarkitell
Mar 12, 2016 04:59 AM
petemohr
General Tech Help
Jan 2, 2015 08:38 PM
forcemajeure
Oct 24, 2013 09:16 PM
kench
May 31, 2013 07:59 AM
Olsic03STR
16
Sep 28, 2012 11:53 AM
