Oil Pan Gasket Replacement
Old Jun 25, 2008 | 11:16 PM
matl's Avatar
Default Oil Pan Gasket Replacement
Hi guys i found an old post on this that said it was an extensive job, i've got moderate experience and was wondering if this was something i could take on in the garage? Are there any DIY on this? Thanks!
Mat
Old Jun 26, 2008 | 02:44 PM
spielnicht's Avatar
Default RE: Oil Pan Gasket Replacement
I think the biggest challenge is removing the transfer case on the 2.5 and 3.0 engines. Aside from that, doesn't look too bad when looking at the instructions from Jaguar.
Old Jun 27, 2008 | 12:59 PM
matl's Avatar
Great! Are there any special tools needed ro remove the transfer case? thanks
Old Jun 28, 2008 | 02:32 PM
Jagtech's Avatar
you only remove the transfer case if its a manual transmmison. if you pull the axle out and damage the internal seal(can not be service) you will have to replace the transfer case
Old Jun 28, 2008 | 10:48 PM
matl's Avatar
Yes mine is manual, any recomendations when removing the transfer case not to damage it? thanks
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
jehart49
Sep 12, 2015 05:36 PM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
