Oil pan replacement
Old Apr 29, 2012 | 04:43 PM
gperna's Avatar
Smile Oil pan replacement
Has anyone changed an oil pan on a 2002 Xtype 3.0
What am I getting into if I do it myself?
Thanks any info is appreciated
Old Apr 29, 2012 | 08:09 PM
jaglover922's Avatar
it's pain to do in the air on a lift, especially if you have rusted out bolts. So I can only imagine it's a pain to do on the ground.
Old Apr 29, 2012 | 08:16 PM
Ian D's Avatar
I haven't done it myself, but good luck with dropping the subframe, a good few bolts around the sump, dropping the exhaust out the way and of course getting oil all over yourself.
Old Apr 30, 2012 | 08:09 AM
pab's Avatar
pab
Check other threads on this list. Replacing the oil pan is really tough because one of the bolts is hidden under the transfer case and can't easily be accessed. Some people have drilled through the transfer case to reach it while someone else said, recently, that the were able to access it by bending the handle of an open-end wrench and being able to slip it into the space between the pan and the transfer case.
Investigate this further BEFORE starting to unscrew the accessible bolts...
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Apr 30, 2012 | 08:37 AM
gperna's Avatar
All
Thanks for the info on this!
I have looked for threads on this and have found none. But thanks again for your input.
gperna
2002 Type X 3.0 needing a new oil pan
Old Apr 30, 2012 | 08:56 AM
joycesjag's Avatar
Here is the link that pab mentioned above:
https://www.jaguarforums.com/forum/x...ket-faq-11221/
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
