Only drivers side headlight is out AND high beam stalk won't stay... new bulb doesn't fix it???
Old Jan 11, 2009 | 11:14 AM
NoPaint's Avatar
Default Only drivers side headlight is out AND high beam stalk won't stay... new bulb doesn't fix it???
So the drivers side headlight is out. New bulb doesn't fix it AND the high beam stalk won't stay back to hold the high beams on now. What could this chain of events be?
Old Jan 11, 2009 | 01:10 PM
SpartanX's Avatar
Default RE: Only drivers side headlight is out AND high beam stalk won't stay... new bulb doesn't fix it???
Headlight Fuse? I'd check that first. As far as the switchgear goes, you may need a new one if it's damaged. I've had to replace it in my old Honda Prelude when it wouldn't engage the high beams without me holding it.
This also may be a great excuse to get an HID kit Good Luck
Old Jan 11, 2009 | 07:12 PM
NoPaint's Avatar
It was the fuse! The headlights ground was loosish too so that was fixed. Fixing those two problems fixed the high beam stalk. I think they have designed it so that if you have a headlight burn out you cannot just drive with the highbeams on and also I like there being a fuse for each side instead of just one for both lights so you dont suddenly go lightless. Thanks again friends.
Old Jan 11, 2009 | 07:39 PM
christo's Avatar
Wow that is good to know. I would have thought the stalk was broken and just replaced that or swapped out the bulbs. Good work!
xjrjag
Nov 27, 2025 09:16 AM
Guernz
Jan 17, 2016 12:22 PM
Aranon
Sep 3, 2015 07:56 PM
johanasu
Sep 3, 2015 12:39 PM
xk8don
General Tech Help
Aug 29, 2015 11:10 AM
