Over heating
Old Mar 4, 2007 | 04:38 PM
racerx82's Avatar
Default RE: Over heating
Belt tensioner has a tight spring built into it that keeps "tension" on the belt and pump. Serves two purposes, keeps the belt tight at the appropriate tension and keeps it from slipping off the pulley. I'm gonna guess the recommended belt change interval is 60K? Maybe 80K tops on some models (which is pushing it) anyway.I replace all my belts at 50K reguardless...my anti freeze every 3 years, brake fluid at every brake change, trnas fluid every 3 years. I'm old school I guess.
The spring gets weak and does not provide the accurate tension against the pump. This will cause slippage and may cause more problems like the belt flying off....
My advice is, why not change it? You're doing all the work; everything is apart....what’s another 25 bucks to make it right?
Once again, why do it 1/2 a$$
Just my 12 cents worth. (I don't come cheap)
Old Mar 4, 2007 | 07:08 PM
bigdreams05's Avatar
Preventative maintenance never hurts! If 20-30 bucks is going to save me headache later on, then it's money well spent!
Old Mar 4, 2007 | 07:14 PM
racerx82's Avatar
Amen brother, and that's all I’m saying....The service schedule is designed as a guide for normal driving folks with regular maintenance schedule intervals...i.e. 10, 20, 30, 40K .....Miles inspections....this is where they would hopefully catch an early failure of some part....
But as we know....it doesn't work out that way....
You mean to tell me you would trust a plastic/rubber belt up to 100K??? If you do, you're a better man....
I'm the kind of guy that would spend the extra 25 bucks to get all the parts replaced....and not worry about it....spend 25 now or 2500 when the belt slips, overheats your aluminum head and cracks it??
But, to each his own...
Old Mar 4, 2007 | 07:27 PM
aquill1's Avatar
especially when if you worry about your knuckles staying scabless and your back hurting all at once or spread out a few more times!
Old Mar 4, 2007 | 07:29 PM
racerx82's Avatar
lol, good point!
Old Mar 4, 2007 | 07:38 PM
aquill1's Avatar
I only have the back hurt because it takes me about 8 times longer than it should to do everything! Oil change 10 minutes....Me changing the oil...turns into an hour!
Old Mar 4, 2007 | 07:45 PM
  #28
racerx82's Avatar
Another one of them tim allen kind of guys huh....
Old Mar 4, 2007 | 07:55 PM
aquill1's Avatar
Yeah I guess! Couple of exceptions though 1) Don't end up in the hospital (at least yet) 2) haven't had any fires (yet) well I haven't my dad did start a van on fire....wasnt' me though his idea 3)Don't have a coffee mug with my name on it at the hospital! Lot more careful than I have to be-alright I'm **** ok are you happy!
Old Mar 4, 2007 | 09:21 PM
  #30
racerx82's Avatar
What was that part about ****..you like it...huh....what's all that about..
Old Mar 4, 2007 | 09:29 PM
  #31
aquill1's Avatar
I'm **** and worry about things not being perfect so I am **** about it and just keep thinking and thinking and thinking about it...got the drift?
Old Mar 5, 2007 | 12:03 PM
  #32
I spoke with a friend of mine that had an S-type and replaced the #2, 4, and 6 cylinder coils since they are the easiest to get to and it threw his timing way off. It caused for him to loose a lot of gas mileage and he had a lot of misfires. I'd think twice about doing the job half-a$$ed if I were you for more than one reason man! It might cost you a lot more in the short AND long run! I though that the car would simply not respond as well, but it turns out to be more than that.
Old Mar 5, 2007 | 02:07 PM
  #34
I know what you mean about us Americanos not giving two craps about the planet! After all we are by far the largest consumer of natural resources. But in my defense, I recycle all of my plastics, paper and bottles. I'm a ***** about my car though! I do oil changes every 2500 miles. I recycle that oil! I do tranny fluid changes every 6 months! I recycle that oil as well. I change belts 10K miles before estimated life span and I take my coolant to be changed at a shop because I don't know how to dispose of it properly! I'm no tree hugger, but I hate the American way of life that doesn't give two craps about our one and only home planet! I wish things could be different for everyone else!
Old Mar 15, 2007 | 04:58 AM
  #35
X2 Jag's Avatar
Well guys I got the Pump and Thermostat for free in exchange forrepairing the guys laptop. [/align]I will put the parts on this week! I miss the Jag already....im running out of "fun" on the Mustang right now. [/align]
Old Mar 15, 2007 | 10:09 PM
  #36
aquill1's Avatar
Good luck x2
Old Mar 18, 2007 | 03:55 AM
  #37
X2 Jag's Avatar
OK I handled the pump and Tstat. Car is running smooth now and back to normal. Thanks!
Old Mar 18, 2007 | 06:52 AM
  #38
04Xtype's Avatar
Nice one on the fix
Old Mar 18, 2007 | 02:59 PM
  #39
X2Jag........all sorted, great! Glad to hear it.
[sm=closed.gif]
JC
Old Mar 19, 2007 | 11:54 AM
  #40
Congrats! Always a good feeling when the baby is running smooth again.
