P0420 code X-type 3.0 - need help
Old May 23, 2022 | 03:51 PM
Heather555's Avatar
Default P0420 code X-type 3.0 - need help
This one is stumping me…. the car is throwing a P0420 code, but it’s running fine. No smell, no smoke, no power loss, misfires, etc. It’s running very normally. I recently had all the spark plugs replaced as regular maintenance and then a few days later this code showed up. I replaced the upstream O2 sensor and the code came back. Would this be a cat problem? I’m used to those smelling like rotten eggs. Spark plug harness would cause misfire…. Should I replace the downstream O2 sensor? Anything else I should check before I end up disassembling half the car? Our local Jag guy isn’t reputable any longer, sadly. I’ll have to take it to a general shop.
Old May 23, 2022 | 05:21 PM
Dell Gailey's Avatar
Bank 1, change both sensors and don't buy cheap internet ones that nearly always fail or don't work initially. Use Denso or Bosch
MisplacedPriorities
Aug 20, 2022 02:41 PM
Bigvettefreak
Oct 24, 2015 08:47 PM
12yrold
Oct 27, 2012 04:06 PM
dvd711
Sep 11, 2012 05:32 PM
Tracy
Jul 13, 2009 11:47 PM
