P1643 Problem
Old Yesterday | 04:47 AM
Tony Clayton's Avatar
Default P1643 Problem
I initially posted this in the wrong place as being a newbie it takes a little time to find my way around. My apologies.
I have a 2.1 litre petrol X-type that has developed a gearbox error message and is now stuck in limp mode.
Our local Jaguar garage has checked the wiring and says it is a error in the gearbox.. A nearby gearbox specialist says that it is not, and will be an electrical problem, leaving me very confused. I have been told that the problem may be the TCM, but nobody other than Jaguar themselves seems to have a matching TCM. Mine is 2x43-72401-JA but the only 2nd hand TCM I can locate has -JC instead of -JA. Is the difference significant? A new TCM seems to be £800+, and the car is only worth twice that, and I cannot be sure that it will solve the problem.
If I fitted the -JC would that matter or would it create problems?
I suppose the only way out is to buy the -JC TCM and try it, and if that does not work return it for a refund.
Any help more than welcomed as nobody in this area seems able to help
Old Yesterday | 05:17 AM
Peter_of_Australia's Avatar
I know that many here on the forum despise AI answers on any kind of problem.
I, however, check, what AI has to say about it, and decide then by myself, if it makes sense or not.
In this case the AI answer is pretty much, what I would have written as well, thus it saves me the typing:
For Jaguar vehicles, the P1643 diagnostic trouble code indicates a CAN ECM / TCM Network Malfunction, representing a communication fault between the Engine Control Module (ECM) and the Transmission Control Module (TCM). This issue is commonly associated with Jaguar X-Type, S-Type, XJ, and XK models.
Common symptoms include the Check Engine Light and Gearbox Fault Light illuminating, hesitation during acceleration, shifting issues, and restricted performance (such as limited throttle opening or being stuck in a specific gear). In severe cases, the vehicle may experience engine stalling or a no-start condition.
The most frequent causes are:
  • Damaged wiring harnesses or corroded connectors between the ECM and TCM.
  • A faulty Transmission Control Module (TCM), sometimes due to internal water damage.
  • Low system voltage or a weak battery causing network instability.
  • CAN bus circuit shorts or open circuits.
Repair typically involves inspecting and repairing the wiring harness, cleaning connectors, or replacing the TCM. Professional diagnostic equipment is often required to accurately troubleshoot the network communication failure.
THUS: If you go ahead and buy a new TCM (not sure where to get one), you are simply throwing money at the Jag without knowing, what's wrong.
As you can see above, in can be many things, and this includes many different expensive modules.
Note: Any swap of modules comes potentially with issues of non-compatibility - i.e. bigger problems.
I'd definitely start looking at those issues, which are cheap to fix, like:
i.e.: Check cables, check connectors, and don't forget to check ground connections! Check ground connections for corrosion.
And how's your battery doing?
It's hard to give an exact voltage, but if you measure anything below 12.7V with engine off on the battery, this might be cause to start wondering, if a low battery could be the root of all evil...
Also: Use at lease 2 different multi-meters to measure the voltage, as a multimeter, with its internal battery being low, could give you also wrong measurements of all kind...
And:
Can you see any indication of water damage? Water coming thru the windshield?
Old Yesterday | 06:35 AM
Many thanks. Battery voltage is 12.3 V so that looks like a starter. I just need to find someone with a new battery to try. Now I find that my headlights do not work unless I pull back on the light stalk. I must admit that I am beginning to despair and want to replace the car, which would e a shame.
Old Yesterday | 08:10 AM
If you don't find a new battery, try a charger. I use CTEK chargers.
Pulling on stalk should be high-beam!?
Sounds like your low beam does not work, just high beam?
Blown bulbs? Or fuses? Or defective relais?
Old Yesterday | 09:43 AM
Thank you again.
When I try to switch on my headlights only my sidelights work. When I pull the stalk the main beam comes, so it is not the bulb. The fuses look OK but having never tried to change or test them…..
Old Yesterday | 11:03 AM
dh53's Avatar
I just had a gear box fault and a CAN bus fault code. Knock on wood, it appears it was corrosion in the TCM connector itself. Some mice made a cozy home under my cowl blocking the drainage of water that normally goes down the windshield and through some hollow spots in the front fender/frame out to the ground. Somehow I'm guessing this caused water levels to rise and flow down or wick down to the wiring harness inside the car to the TCM. I did not find the path of the water, I'm basing my theory on the 500 other posts here in the forum of people who had water damage to their TCMs.
My TCM connector is in the pic attached. I had fault code P0720, output speed sensor issue. The upper right circled pins go to the trans out put speed sensor so that made sense. I got in there with a dental pick, tooth pick, and cotton swabs and cleaned up what I could then sprayed it with electrical contact cleaner, sanded the pins very gently with 400 grit sand paper, then electrical contact cleaner again. Electrical contact cleaner on the body side connector as well.
The bottom left circled pins were nearly as corroded but you can't see it well in this picture. Corrosion on these pins was shorting the CAN bus giving me P1606, a similar error to yours.
All told the fix cost me a couple of hours and $0.
Old Yesterday | 09:23 PM
Originally Posted by Tony Clayton
Thank you again.
It still could be the bulbs. I assume you know that even though the light for high AND low beam are originating from the same bulbs, the light for high and low comes from different filaments inside of those bulbs...
Also: Check the relays.
Tony Clayton
Apr 17, 2026 04:26 AM
ericnunez
Jan 20, 2024 09:12 PM
JoMa93
Mar 28, 2022 12:57 PM
04jagX
Jun 6, 2018 06:33 AM
Louenigma
Jul 9, 2015 09:07 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
