P1647
Old Sep 7, 2019 | 06:56 PM
Haydedps's Avatar
Default P1647
Hi all
i have a Jaguar x type 2003 v6 2.0 Ltr petrol engine.
okay, does anyone know why the code P1647 and of course the MIL is on. Here’s what’s happened so far: took the car for its yearly MOT test and if failed the emissions tes and highlighted the code P1647. The lambda sensor was removed by the garage and replaced with a new on, went through a new MOT and passes the emissions test and is now road worthy.
so far so good. Back at home I then poured 500ml of Cataclean, checked all the fuses and connections, all good.
the the following day the MIL is on, I then put my isoft or connected to the OBD to checks for faults only to find the one fault which was bank two sensor two, P1647.
i should add the sensor that was taken out was a Denso. The replacement was also a Denso all done through a garage.
am I missing something here or should I be looking at the ECU?
i would be appreciate anyone who can shed some light on this frustration
lastly, would it had been better if had put on a Bosch sensor
thanks as always guys
Hayden
Old Sep 7, 2019 | 07:40 PM
Dell Gailey's Avatar
P1647 is Bank 2 (radiator side), Sensor 1 (upstream).
Make sure they replaced the correct one firstly, then check all the wiring hand over hand to see if there is a chaffed section, lastly unplug sensor and clean the contacts well of any corrosion, dirt, oil, grease, etc.
And check the fuse.
Old Sep 9, 2019 | 09:04 AM
Haydedps's Avatar
Thanks Dell, I will investigate and get back to you with the results.
Zarathushtra
Jun 3, 2017 07:54 PM
Shyaam
Jan 31, 2017 11:50 AM
Stumpygop
Jan 11, 2015 05:48 AM
Munro
Jun 20, 2013 07:33 AM
Steve_Jaggar
Aug 10, 2012 12:12 PM
