Parking sensors problem
Old Aug 24, 2021 | 11:28 PM
Kuba1997's Avatar
Default Parking sensors problem
Hi guys I have a small problem with my revere parking sensors on my jaguar x type 2.1 v6 petrol 2002 when I put it in reverse it makes a long beep but the sensors don seem to be doing their job I have checked all of them they are all working what do I check next
Old Aug 25, 2021 | 02:06 AM
Dell Gailey's Avatar
Long continuous beep is parking sensor malfunction. Use the search function in this forum.
EXAMPLE =
https://www.jaguarforums.com/forum/x...arting-195560/
Old Aug 25, 2021 | 04:20 PM
Thermo's Avatar
Veteran: Navy
Kuba, if all the sensors are clicking/chirping, but you are getting a long tone, then odds are, your parking module is toast. There is a potential that the echo signal from one of the sensors is open so the module is not seeing it, but that would be a first.
Old Aug 25, 2021 | 08:44 PM
Kuba1997's Avatar
Hi so how do I check the module ? the sensors are making a noise
Old Aug 26, 2021 | 05:54 AM
Thermo's Avatar
Veteran: Navy
Kuba, the only check that you can really do is replace the module. There are no checks that you can really do unless you are very knowledgeable with electronics and hten you would need to get a schematic for the module (good luck in finding that). You are down to an either/or situation. You either have a bad module or a bad wiring harness. The modules fails a lot more than the wiring harness does.
Old Aug 26, 2021 | 02:00 PM
All I would add is your statement that you say "all of them are working". So my assumption is in checking all 4 of them each separate sensor makes a "clicking" sound? If that is indeed a fact then Thermo is correct in his appraisal.
chooseysuzy
Aug 13, 2017 05:02 AM
johnban
Jan 28, 2015 12:07 PM
Bkny85
Feb 19, 2014 09:43 PM
chevyman46933
Nov 2, 2010 07:15 AM
