parts and labor
Old May 19, 2010 | 02:05 PM
lennyjodon's Avatar
Default parts and labor
does anyone have any info on oil pan gaskets on xtypes?
Old May 20, 2010 | 03:37 PM
Thermo's Avatar
Veteran: Navy
Lenny, the gasket is like $50. As for the labor, plan on spending about $1000. IT is a fairly drawn out thing and requires lots of dis-assembly of the underside of the car. So, unless it is making a big mess, I would recommend just checking the oil a little more often.
I'm sure some others will pipe in here shortly with what they spent getting the gasket replaced. Please note, some shops will attempt to bypass a lot of the labor and will drill out a hole in the side of the transfer case. THIS IS A BAD IDEA!!!! The transfer case is weak enough as it is. You don't need to be removing more metal from it, making the case weaker. Sure, it may save you $500 off the labor, but potentially at the cost of a new transfer case (to the tune of like $2500).
Scott B
Oct 24, 2015 01:29 PM
johndahlheimer
Sep 16, 2015 05:44 PM
JimMLiny
Sep 9, 2015 08:13 PM
1100me
Sep 7, 2015 06:26 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
