Passenger side door locks
Old Feb 19, 2007 | 10:07 PM
altownsend's Avatar
Default Passenger side door locks
I have a 2002 X-Type Automatic with 61000 miles on it.
I just purchased it in December 2006. Any way, when I lock and unlock the doors, the passenger side front and rear doors do not lock and unlock. The alarm will arm, and if I open the passenger side front or rear door, the alarm will sound.
When I press the lock on the key, the drivers side front and rear doors will lock, but not the passenger side front and rear doors. I have to manually lock and unlock the passenger side front and rear doors from the inside of the car.
Anyone know what might be the problem?
Old Feb 20, 2007 | 12:55 AM
altownsend's Avatar
Default RE: Passenger side door locks
When I click the lock/unlock button on the keyfob, I do not hear anything at the passenger side front and rear doors. When I manually unlock and lock either passenger side front and rear door from the inside of the car, the drivers side doors lock and unlock as well. However, if I manually lock either the passenger side front or rear door, the other passenger side door does not lock or unlock, yet there is a sound like the driver side locks are responding.
Any ideas, folks?
Regarding the linkages, are they connected to the actuators and push and pull the device that activate the locks?
Is there a write up on removing and replacing the actuators?
Is there an after market supply house where I can purchase replacement actuators?
Thanks in advance
Old Jan 20, 2018 | 08:55 AM
MEM109's Avatar
Im in the same boat,will follow your post Love my 99 XK8 to death and its the little things that keep it interesting.
MEM109
Old Jan 20, 2018 | 10:43 AM
avern1's Avatar
You have brought up a post that is over 11 years ago. It would be best if you posted your problem and what is happening in a new post in the X100 forum. There the members can help you out. You say you have the same problem. Give a little more info in your post and we can see what we can do.
99xk8guy
Sep 29, 2025 10:51 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Dicque
Sep 19, 2015 12:53 PM
Bowman
Sep 15, 2015 06:54 AM
bdboyle
Sep 4, 2015 06:16 AM
