Performance Thread Sticky?
Old Jun 19, 2007 | 11:37 PM
SpartanX's Avatar
Default Performance Thread Sticky?
I just got my X about 2 weeks ago, and I haven't found much in terms of getting more power out of my X. I have the 2.5L mated to the manual, which is enough to zip around town, but I could always use more power
Any ideas?
Old Jun 20, 2007 | 12:14 AM
04Xtype's Avatar
Default RE: Performance Thread Sticky?
U cud start with exhaust, intake, and a chip (dependin on how much u want to spend) That will get u about 40 extra horses.
Old Jun 20, 2007 | 09:20 AM
bigdreams05's Avatar
it will also rid 2.5K out of your wallet! Be a wise shopper. I would say, if you want more power, the X isn't the car for you. You should try the R line of Jags!
Old Jun 20, 2007 | 02:00 PM
BuckMR2's Avatar
ORIGINAL: SpartanX
Any ideas?
Why did you buy a 2.5 if you want more power?
I hear this all the time and this is my responce..trade it in for a 3.0
Old Jun 20, 2007 | 02:52 PM
SpartanX's Avatar
I couldn't find a 3.0L manual in my area at the time I wanted to buy. I figured I could get the usual I/H/E and get at least another 20 HP, but apparently it's hard to find these parts at all.
Considering the 2.5L is a Ford? engine, I didn't think it'd be this hard to find performance parts.
Old Jun 20, 2007 | 02:53 PM
I agree with Biggie n Buck.......the 2.5 aint built for speed[&:]
Cruissinnnnnn
Jim
Old Jun 20, 2007 | 02:57 PM
BuckMR2's Avatar
ORIGINAL: SpartanX Considering the 2.5L is a Ford? engine, I didn't think it'd be this hard to find performance parts.
Wrong its a modified version which is why it has more power to start with then the 2.5 Ford engine.It has modified head,ecu,etc.Ford ECUs are a lot easier to remap eg superchips than the X.
Old Jun 20, 2007 | 03:09 PM
SpartanX's Avatar
ORIGINAL: BuckMR2
How is that "wrong"? Perhaps if I said it was a Chevrolet engine, that would be "wrong".
It's a modified version of the Ford 2.5L, which still makes it a Ford engine. Mind you, there is a Ford 2.5L that just so happens to make the same power...Think Ford Countour SVT...
Old Jun 20, 2007 | 03:46 PM
BuckMR2's Avatar
Ford Contour...whats one of them...must be a US car??
The most significantcarry overs from the Mondeo are the suspension,brakes and basic engine block(I'll repeat that incase you missed it basic engine block) but so much work has been done on each of these components by Jaguar that it hardly seems fair to describe them as Ford cast offs.(Not your words I know)
Taken from X type The inside Story:-
Both 2.5 and 3.0 engines are derived from the AJ-V6 already used in the S Type, itself already derived from the AJ-V8 as used in the XK8.Jaguar has spent a lot of developmentdiminishing the shortfall between the smoothness of the counterbalanced V8 and the inherent shortfall with the V6.The 2.5 is derived from the 3.0.There is a wide torque spread to help driveability with over 90% of peak torque available from 2500-6000rpm and 80% from 1500-6800rpm.
2 key features contribute to this..the constinuously variable (not 2 position) cam [hasing on the inlet cams,plus variable induction geometry.Two butterfly valves in the induction manifold/plenumopen or close under control of a 32 bit Denso egine management computer to feed air seperatly to each bank of 3 cylinders or link them to exploit beneficial resonances.The 2 butterflies allow 4 operating modes (closed/closed,closed/open,open/closed,open/open) three of which are exploited.The variable cam phasing, a drive by wire throttle, new 12 hole fuel injectors and a close coupled catalysers (1 per bank) help the engine meet EU4 emissions standard and LEV regs in US and Canada.
Now go compare to your Ford Contour/Mondeo...
Re: Chevrolet (are they another US car maker?)
Old Jun 20, 2007 | 06:33 PM
Nuthin like a bit of banter.....lol
JC
Old Jun 21, 2007 | 06:40 PM
gotti15's Avatar
Well said!
Old Jun 25, 2007 | 03:17 AM
04Xtype's Avatar
haha, there has to be a little, keeps the forums entertaining
aholbro1
Dec 29, 2024 06:46 PM
SeismicGuy
Oct 14, 2015 09:33 AM
DustysSon
Sep 13, 2015 04:17 AM
scottatl
Sep 4, 2015 08:08 PM
