Please help
Old Jul 27, 2020 | 04:28 PM
CJ Sepull's Avatar
Default Please help
I own a 2005 jaguar x type 3.0 manual and the other day I was driving home from school and when I went to shift into 3rd the car wouldnt go in gear, i put the car in neutral released the clutch then pushed it in again and tried to go into 3rd. When I put the shifter in place I heard a snap and now when I put the car in any gear it acts as if it were in neutral and the clutch wont grab. What is this and how can I fix it?
Old Jul 27, 2020 | 07:02 PM
Thermo's Avatar
Veteran: Navy
Sounds like you snapped the shift linkage. Unfortunately, this is one of those things that you are going to have to hand over hand the shift linkage to figure out where it broke. I would say you can do a quick check and look on the side of the tranny for where the cable attaches and then have a second person run the gear shift through the gears and see if the little lever on the side moves. If that lever moves, then your problem is internal to the transmission. If the lever doesn't move, then you have a problem either in the shifter or the cable.
Old Jul 28, 2020 | 08:22 AM
Welcome to the forums CJ Sepull,
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Notacop
May 15, 2020 03:34 PM
approx
Feb 25, 2020 12:53 PM
Preacher-Steve
Nov 21, 2016 06:36 PM
tibam13
Nov 11, 2014 03:54 AM
rothe
Nov 2, 2014 07:43 PM
