Post Clutch Replacement & Shifting
Old Dec 16, 2013 | 03:37 PM
drdnaga's Avatar
Default Post Clutch Replacement & Shifting
About 3 months ago I had a new clutch, flywheel and pressure plate put in. The car rides great BUT now I have some stiffness getting the car into gear. When I go into 1st or reverse it is stiff and needs some pushing. Once I am going it is as smooth as silk. Then this will go away and out of nowhere get difficult to shift.
The transmission is not slipping, I have changed the fluid to OEM Jag and I am a bit frustrated. A Jag tech told me to bleed the entire brake system again as well as the clutch.
Any additional thoughts, comment, input??
2003 Xtype 5 speed 103K miles.
David
Old Dec 17, 2013 | 11:09 PM
drdnaga's Avatar
master clutch cylinder?? Any input please?
Old Dec 18, 2013 | 01:07 PM
Justink201's Avatar
Did you bleed it again?
Old Dec 18, 2013 | 02:36 PM
drdnaga's Avatar
I'm going to. I am going also change our my master brake cylinder - I see that it has a leak where it meets the brake booster. I will also change out the Master clutch cylinder THEN bleed! I really hope that these two do the trick.
Old Dec 19, 2013 | 03:55 PM
robiwhan's Avatar
keep me posted on progress if you can
BrentGardner
29
Dec 16, 2024 12:13 AM
Isoruku
Jun 19, 2020 12:54 PM
TheWarlock
Sep 7, 2015 09:30 PM
Aranon
Sep 3, 2015 07:56 PM
Aranon
Sep 1, 2015 01:00 PM
