pulled some codes... need some help...
Old Oct 19, 2009 | 09:03 PM
afonda's Avatar
Default pulled some codes... need some help...
Pulled the following codes:
P0171 System too lean / bank 1
P0174 System too lean / bank 2
P1111 Manufacturer control fuel air metering
P1000 fuel air metering aux emissions controls
Not sure what these are point to... but any suggestions would be great.
Thanks,
Andy
Old Oct 19, 2009 | 11:26 PM
mohrd's Avatar
Isn`t there a sticky or FAQ on 0171 and 0174 yet
Search the X-Type forum on the site for vacuum leaks, IMT o-ring, PCV hose, and you'll come across the likely three culprits. All easy fixes.
Let me guess. Just started as the weather got colder?
Old Oct 20, 2009 | 01:56 AM
BuckMR2's Avatar
Might just be one problem if all 3 codes were logged at the same time.Sometimes a leak in a pipe or seal can cause other sensors further downstream to log faults.Check the thread on how to remove and refit the cranckcase breather hose which is a common failure and hence the newer sturdier pipe for a £5 in under 2 mins
Old Oct 21, 2009 | 03:13 PM
dennis black's Avatar
20 Year Member
read my thread i have a wrirte up with pics (my x-type projects asnd installs)
Old Nov 1, 2009 | 03:20 PM
Jamey's Avatar
The Weather gets cold...and I get the System Too Lean and 02 sensor codes. It warmed up today and my engine light went off.
I'm in for an oil change this week...should I have them check the codes anyway?
Old Nov 1, 2009 | 03:46 PM
mohrd's Avatar
Happens more in the cold. Check for one or all three vacuum leaks.
Old Nov 1, 2009 | 05:27 PM
Disco stu55's Avatar
yeah mine popped uplast night when driving, and went away randomly
Old Nov 3, 2009 | 02:32 PM
afonda's Avatar
Looks like i got it fixed. At least the engine light is out and the car seems to be running much better (no rough idle at start up).
The hose going from the PCV to the intake manifold / it runs right along side the throtle body, was split right down the middle. I tried to fix it once before by sealing it with electric tape and it worked at the time because the split was very small. I guess the hose was really a piece of crap because the split was almost the entire length of the hose now.
Anywayz.... $1.59 for a piece of new hose and all is well.
Lets hope the codes dont come back.
Old Nov 3, 2009 | 06:58 PM
BuckMR2's Avatar
Originally Posted by BuckMR2
Check the thread on how to remove and refit the crankcase breather hose which is a common failure
Thats the same pipe as mentioned above (PCV hose to the intake manifold = crankcase breather pipe)...oil lies in the bottom of the pipe causing it to deteriorate.
Glad its sorted
dsnyder586
Dec 29, 2024 07:39 PM
bdboyle
Sep 16, 2019 05:58 PM
jzanone
Dec 30, 2015 05:50 PM
LnrB
Sep 24, 2015 11:16 AM
SeanU
Sep 14, 2015 04:31 PM
