Purge valve solenoid,code p0447
Old Jun 3, 2012 | 07:28 PM
marshd3's Avatar
Default Purge valve solenoid,code p0447
I got code P0447 and sure enough the purge valve solenoid is rusted out and the circuit is open. This being said, with the circuit open will this cause the engine to run rough at idle and sputter when under load? Also, the gas milage is only 22.5 per gallon highway and 20.0 combined.
Anyone know where I can buy the solenoid (Jag ref # C2S8605) at a reasonable price? Here in Eastern Canada the Jag Dealer wants $179.00 plus the usual 15% sales tax. Allways get better deals State side. Thanks in advance!! 2002 x-type, 2.5
update for the above: I replaced the purge valve solenoid from a 2005 Mustang GT 4.6 li. It's identical for $125.00 at the Ford Dealer. Gas milage went from 22.5 to 27 mpg highway. This did not cause the sputtering.
The sputtering issue: I removed the spark plugs, again (as you know is a pain because the manilfold has to be removed) and 5 out of 6 plugs were burning perfect, (light grey) and one plug was brown. Longer story short it was the coil pack. I replaced it now the little Jag runs like a Champ. Now getting max. 35.4 mpg highway.
Old Jun 3, 2012 | 08:08 PM
Tony_H's Avatar
I get my parts from here
British Parts UK - Jaguar | Land Rover spare parts at British Parts UK
Old Jul 28, 2017 | 06:16 PM
Dell Gailey's Avatar
Purge valve
Old Jul 28, 2017 | 06:17 PM
C2S8605
Old Jul 29, 2017 | 04:03 PM
Old Aug 5, 2017 | 06:18 AM
Vitaliy Sakharchuk's Avatar
Originally Posted by Dell Gailey
Is thison the x type location of the solenoid? Because my engine looks different.
Old Aug 5, 2017 | 08:00 PM
The canister vent solenoid is located on the canister above the rear subframe
silkcat
Jan 18, 2025 04:29 AM
bamforp
Aug 14, 2024 05:36 PM
ccfulton
Sep 20, 2015 05:15 PM
TexasCat
Sep 8, 2015 04:36 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
