Question about coolant reservoir tank
Old Feb 21, 2014 | 12:15 PM
04xtype04's Avatar
Default Question about coolant reservoir tank
Is there any way I can drive my car before I get the new tank? The nipple broke off to the hose on the left side (towards passenger side). The hose appears to go to the top of the engine near the fuel injectors. What if I taped the end of the hose off and taped the hole in the tank off and filled it with coolant? Would it at least be driveable for a couple days?
Last edited by GGG; Feb 21, 2014 at 07:25 PM. Reason: edit typo in thread title so it appears in searches
Old Feb 21, 2014 | 02:58 PM
Thermo's Avatar
Veteran: Navy
04xtype04, to make the car driveable, you would need to seal things up. Your car runs truely on a pressurized system setup. As the car warms up, the tank gets pressurized (hence why they tell you not to open it with it hot as the water can flash to steam with the loss of pressure and burn you). So, you would have to plug the hose that broke off (I recommend sticking a bolt in the end and then clamping down on that) and then screwing another bolt into the open hole and sealing that back up. The purpose of the line that broke off is to provide a high point vent in the engine so any trapped air can get out. As long as you still have a level in the reservoir, you shouldn't have a bubble in the engine.
Old Feb 21, 2014 | 08:17 PM
04xtype04's Avatar
The resevoir is empty I believe
Old Feb 22, 2014 | 12:44 PM
Alfadude's Avatar
I understand you want to drive the car and how much it sucks to not have transportation, but this is one time when it's best to take your lumps and wait until you get the new tank. Why take the chance? You overheat it and you could be down for a lot more than a couple days. Hang in there!
Old Feb 22, 2014 | 01:13 PM
04xtype04's Avatar
Yea, I agree. The tank should be here in a couple days. I can rough it til then, install the tank and put in fresh coolant and be good... Hate to risk frying a 4 or $5000 engine if the coolant leaked out because I was impatient.
Old Feb 23, 2014 | 05:45 PM
04xtype04's Avatar
Should I do a flush and fill or just add a gallon of premixed coolant?
Old Feb 23, 2014 | 05:50 PM
Alfadude's Avatar
Unless the coolant needed to be changed anyway, just replace the tank, fill it up and call it good.
KarimPA
Sep 12, 2015 08:15 AM
OkieTim
Sep 8, 2015 04:48 PM
1100me
Sep 7, 2015 06:26 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
