question for the techs, or more of a "huh"
Old May 14, 2008 | 12:14 PM
loaks111's Avatar
Default question for the techs, or more of a "huh"
i previously posted that my cd player is not working. and it was recommended that i disconect the bat. here is the huh part. i had the bat disconnected 3 times this weekend, once to fix my head light and 2 times to try and get the cd player to work. i disconected the negative, like normal for the lights, cd still didn't reset, disconected the positive, cd didn't reset. disconnected the whole thing. still didn't reset. today i pulled the fuse, nothing, pulled the unit and unplugged still nothing. then while i was flipping thru the manual it said i would have to input the code to get the radio to work after disconnecting the bat. after unpluging the unit fuse and bat, it never once asked for the radio code. is this normal.
[sm=wtf.gif] this seems kinda odd to me.
Old May 14, 2008 | 02:00 PM
Dennis's Avatar
ud
Default RE: question for the techs, or more of a "huh"
I have heard that by disconnecting your battery and then touching the lead cables together, that this will discharge an residue voltage stored in capacitors which is holding memory of conditions such as in the case of your CD player.....
Old May 14, 2008 | 02:06 PM
pu5hkar's Avatar
i still need to disconnect my cables from the battery to see if my high beams will self fix...
Old May 14, 2008 | 03:48 PM
BuckMR2's Avatar
pu5hkar
Im off to buy some sunglasses to look at your car signature....nice shine[8D]
Old May 14, 2008 | 04:18 PM
FactoryJaguarTech's Avatar
On jags, nota good idea to touch the leads together.
By default the radio for the US market is set to not ask for radio code after battery disconnect.
Old May 14, 2008 | 04:33 PM
Dennis's Avatar
ud
ORIGINAL: FactoryJaguarTech
Mine asked me for my code..(I have the intergrated NAV system)
Can you elborate on the Battery Cable thing?
Old May 14, 2008 | 05:04 PM
loaks111's Avatar
what would be a good option to replace it. i have contacted
the dealership on another matter, which resulted in contacting
jag, which i was told to suscribe to the tech info and find parts
myself. so seeing as how i have to be my own parts supplier/
installer whats a recomendation for replacement.
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
LnrB
Sep 18, 2015 09:48 AM
Horus
Sep 18, 2015 05:39 AM
veffremov
Sep 9, 2015 01:23 AM
