R R window quirk
Old Feb 29, 2016 | 05:02 PM
Robert Scott Neilly's Avatar
Default R R window quirk
Not exactly a serious problem, but.....
The right rear window in my '03 X operates perfectly (as do the other 3) from either the r r seat control button, or the driver's seat control for same, but when I use the 'Global Locking' feature, the other windows, moon-roof, door locks all do their thing, but not the r r window. I have to turn the ignition on and power that window up with the button.
Any ideas?
Old Mar 1, 2016 | 05:42 AM
santer's Avatar
If you press to open the window then let go of the switch, does it continue or stop?
If it stops, press to open, hold the switch until open and hold for a further 5 seconds or until you hear a click, press and hold the switch to close the window, hold the switch for 5 seconds after it closes or until you hear a click.
Try global closing.
Old Mar 1, 2016 | 08:33 AM
It continues. I've tried the reset, and that part works just fine.
Old Mar 1, 2016 | 10:50 AM
Alfadude's Avatar
Maybe it has to do with the door. When you try the global locking is the door itself locking where you can see the lock button on that door move, or does that stay open? If it stays open maybe that is what is preventing it. When I had my X I had the right rear passenger lock that seemed to stick at times (maybe because I didn't use it much). Maybe that is what is causing the window not to move.
Old Mar 2, 2016 | 09:32 AM
Thanks for the suggestions, Guys, but I re-set the window limits, opened and closed the door, patted the Leaper, everything, yesterday, but still the same problem. And today, everything works!
An English car, with phantom glitches!!?? Whodathunkit?
Old Mar 2, 2016 | 03:31 PM
hlgeorge's Avatar
I'll bet patting the Leaper did it!!
HawaiiRealtor
Sep 29, 2025 03:27 PM
cambridgejag
Feb 13, 2016 06:21 PM
petercanepa
Feb 11, 2016 02:13 PM
labcoatguy
Feb 8, 2016 09:44 PM
tomtomterrific
Feb 6, 2016 05:32 PM
