Radiator Fan Stays Running
Old Oct 1, 2009 | 05:32 PM
Thermo's Avatar
Veteran: Navy
BaltVista, you can pull fuse #25 to de-energize the fan module, which will de-energize the fans.
I would be placing money that you are having a problem with the fan control module. What you can do is access the fan control module and find the white/blue wire on the fan control module. If you connect a multimeter to this wire and set the multimeter to measure DC voltage, you should get a voltage that is relative to the percent on that the fan is. If you are getting zero voltage (with the motor off) but the fans are still running, then that confirms a bad fan control module. If you are getting 12 VDC, then you are looking at either the motor running warm and the fans are running to help cool it down (but this should only take a few minutes at most) or you have a problem with the engine management computer (bad temp input or failure inside the computer). If your dash temp guage is still indicating normally, then you can rule out the bad temp sensor.
If you need more information, let me know and I will do what I can.
Old Oct 1, 2009 | 08:59 PM
Teck4Jag's Avatar
i would check the thermostat,wile your doing that see the condition of the hose (upper) that he thermostat is attached to the base gasket leaks and has a high failure rate,the fan modules on the early x type had issues since day 1,but that was a over heating issue,also good time to check the water pump and any other coolant leaks
Old Nov 11, 2013 | 07:08 PM
cliffbarr1's Avatar
my 02 s type , coolant fan come on as soon as car started running. what could be the problem ?
Old Nov 12, 2013 | 12:56 AM
Justicejamesb's Avatar
@BALTVISTA I would tend to agree with Thermo, because he's the man. But, I would like to know how full the expansion tank is. Is there still coolant in it, or is it all drained out? (It's the tank that sits on the upper right hand corner of your engine compartment, check it and see what the level is…)
@cliffbarr1 how long has it been going on? You can wire your fans to come on when you start the engine. If someone has wired them direct, when you turn your car to "on", not "start", the fans will kick on. Or you have a bad Fan Module, or a leak in the coolant system… something along those lines.
Old Nov 12, 2013 | 10:52 AM
billbjork's Avatar
03 X,2.5
coolant level went down EVERY slowly(inch over 3 months or more). Took the wife to the Doc, 20 miles. went to leave no heater,20 miles home engine temp.barely got to normal but finally did, it never over heated, put her in the garage(car) radiator fan ran for over 5 mins.. Doesn't usually run after shut off.coolant bottle was empty.So remove bottle, found nipple cracked on left side in front of hose clamp.I then cut off nipple at boss, drilled,tapped hole, put in a brass screw in nipple then epoxied around complete area, after it set up reinstalled bottle filled it up and ran it till it was pressurized, so far so good.My only concern is that the brass will expand and contract at a different rate from the plastic and loosen up, I'll have to keep a eye on it
Old Nov 12, 2013 | 12:09 PM
cliffbarr1's Avatar
Jim Justic: Notice it after i replace upper rad hose/ termostat, I bleed all air fr system, to get my heat back, is there a coolant switch in rad. that tell the fan to come on? or the Fan Module does that?
thanks
Old Nov 12, 2013 | 04:00 PM
billbjork's Avatar
Baltvista
If the fan is running after you shut the car OFF it means the temp. sensor thinks it's still to hot regardless what the gauge says, we need to know the coolant level first and foremost then Two things: #1- if the coolant level is very low after you shut the motor off the super heated coolant rushes back to the radiator and upper block triggering the fan to run on until it's satisfied the sensor. and IF you have a weak battery it will kill it to the point it won't restart the car. #2 your fan relay is already at battery voltage it just needs to be told to turn on by a control circuit(a temp. sensor, module, ect..The module controls components by giving them a ground path to turn on.hence the shorted wire theory OR the fan relay is stuck shut (contacts welded shut). In the relay box under the hood pull and swap the relay with one from say the lights( don't put the original one in until you see if it helps)then turn on the ignition then off and see if the fans run.If the fans run on a COLD engine and you plug in the relay and it clicks it;s working AND being TOLD to turn on by 1. temp sensor,2.module,3.shorted or pinched wire. Another test , with the fans running pull the fan relay, see if they stop to eliminate a alternate power source to them, (melted connector, ect.)If it was the thermostat open or stuck shut you would see that on the temp gauge or the heater would be a cold blast.A good scan tool will tell you module problems, engine actual temp. and more and cheaper than $110.00/Hr.
Old Nov 13, 2013 | 03:42 AM
@Cliffbarr1
A bubble in the coolant system will cause these problems. Are you sure that you have it bled correctly? If you need instructions on how to bleed the system let me know and I'll sent them to you.
Old Nov 13, 2013 | 07:03 AM
cliffbarr1's Avatar
Jim Justice: Yes please send me the instruction how to bleed system
thanks
Old Nov 13, 2013 | 12:11 PM
xantic's Avatar
I am reading this with interest as i have the same problem almost.
Old Nov 15, 2013 | 07:29 AM
cliffbarr1's Avatar
FYI : I located the coolant temp switch, behind driver side cyl head, I remove the wire and the fan stop running. I replace the switch so far car is working ok.
regard
Old Nov 15, 2013 | 09:46 AM
billbjork's Avatar
Cliffbarr1
Glad to see you found the problem, sometimes we can't see the forest for the trees or simply over thinking a simple problem it;s easy to do.Were you just lucky or was a systematic diagnose or a last resort?
Old Nov 15, 2013 | 04:31 PM
xantic's Avatar
Can i hijack this thread with a similar problem or should i start a new thread.
Old Nov 16, 2013 | 02:05 AM
cliffbarr1's Avatar
I decided to get a picture dig, and look for the coolant sensor, not coolant temp sensor, it shows the temp sensor on top driver side cyl head between coil, and the coolant behind the same, behind the same head.
Old Nov 18, 2013 | 10:59 AM
skrichard's Avatar
My "better half" has a 1999 XK8 convertible (55,000mi) that just started doing something similar to what was described in this thread. Turn on heat, shortly thereafter very loud fan noise from engine starts up, and I do mean loud. Sometimes it will stop, then start again, sometimes it will keep running whole time while driving even after heater turned off, sometimes runs on after car is turned off and of course battery runs down. Car did over heat on Saturday too. So where would you recommend I start first with trying to id the problem?
Old Nov 18, 2013 | 11:43 AM
Krasi's Avatar
First, find the temp sensor and unplug the cable from it to see it'll make a difference. Check dash gauge too when it's unplugged.
Old Mar 4, 2017 | 01:23 AM
WayneinAus's Avatar
Hi Thermo, I have a 2006 2.1 v6 x-type today this happened to me when I stopped the car and turned off the engine I came back to the car half hour later fan still running. I got home and still running but hot now so I left it till the hoses were cooling, the gauge is working fine, no overheating, leaks or corrosion I disconnected the temp sensor the fan continued to run, I disconnected at the module the large connector which turned fan off. enging now cold plugged back in and fan started up, I am thinking module after your post but don't have a good meter to test, is a safe bet to replace module?? I also have another issue with battery warning light, it comes on sometimes after a short trip when I have stopped and got started again and it will stay on until I go to use the car later when it has cooled a bit or next day, doesnt happen everyday, I have had the alternator replaced as a spark was sure it was at fault, battery seems fine starts cranks really well, does have a slight missing for about a minute from cold start but then perfect very odd behaviour, have you experienced any of this, any help much appreciated.
Wayne
Old Mar 4, 2017 | 08:15 PM
Thermo's Avatar
Veteran: Navy
Wayne, before you go too crazy, I want you to try something first. Go out to your car and make sure that the A/C system is turned off. Then take the car out for a drive (rolling down the windows as needed) so you can get the car up to temp. The last little bit of the drive, make sure you are driving around say 40 KPH or less (want to make the fans come on). If you turn off your car and the fans turn off within a few minutes, then odds are it is not the module. If they continue to run for a long, long time, then it is almost for sure the module. If you find that you can drive the car without the A/C on and the fan work normally, but if you drive with the A/C on and turn off the car to have the fans act improperly, then odds are your problem lies with the A/C unit in the dash and it is not powering down when you turn off the car. What is happening is when you have the A/C on (especially on MAX), it will force the fans to run constantly.
Old Mar 5, 2017 | 12:20 AM
WayneinAus's Avatar
Hi Chris (Thermo) thanks for the reply, the car cold this morning, connected the module main connector and fan started right up, got in started and ran the car up road and to temp fan on all time driving A/C off all drive, got back homw fan still on, turned engine off left car for 2 hours enging pretty cool fan has not stopped, temp gauge gone down, A/C fan off just cooling fan on all time so as you say looks like the module.
A/C works great I replaced the compressor a little while back bought it from USA also replaced alternator as the battery light would and still does come on intermittently although battery seems to have stacks of power (technical term for not tested but seems ok) I know these have a weird charging system I wonder if I do need a battery?.
I will order a new fan module today and update after arrival and fitting.
