radiator fans at full spped during ignition-on
Old May 14, 2021 | 04:55 PM
catfondler's Avatar
Default radiator fans at full spped during ignition-on
Hey guys, I need some help!
2006 Jaguar X-Type 2.5 L AWD, sedan
The radiator fans run at full speed during ignition-on and during driving all the time (A/C is off).
(I've tried a second CFM, too. Same behaviour.)
I've checked:
Coolant sensor: cold, diagnosed temperature is plausible
Air intake sensor: cold, diagnosed temperature is plausible
Fuel temp sensor: resistance ist plausible
Evaporator temp sensor: resistance ist plausible
Discharge temp sensor: resistance ist plausible
A/C pressure sensor (A/C off): sensor wire is at about 1V (according to wiring scheme 0 to 5V)
Engine Oil Temperature sensor: resistance ist plausible
A/C runs ok, if I activate it for test purposes.
No DTC in ECU. (At the moment I'm not able to read Climate Control Unit and Tramsmission Control Unit.)
Why ECU don't regulate the fan assembly? (The waveform is always the same.)
Wiring is 100% ok, because CFM delivers 12V level on control wire and ECU pulses it to ground for realizing the PWM pulses.
This measured PWM waveform (about 93% high, and 7% low) means full speed or means low speed?
I suppose full speed. (?)
CFM: PWM control signal (generator at 15.30V shortly after motor start - later falls to 13,xxV)
Thanks, catfondler
Old May 16, 2021 | 09:36 AM
catfondler's Avatar
The pic in the previous post has the wrong scaling info (because of recall waveform from DSO memory). Time was 5.000ms / DIV (instead of 1.000ms).
catfondler
Old May 12, 2022 | 08:08 AM
faridz's Avatar
Hi Catfondler,
I have the exact same problem with my Jaguar. Fan starts at high speed and stops (after a few seconds) when I switch off the car. Just wondering if you have found a solution yet? Took the car to a mechanic who specialises in Jaguar. He was not able to fix it.
Old Jun 2, 2022 | 01:59 PM
catfondler's Avatar
Unfortunately i haven't resolved the problem until now.
The automatic transmission fluid temp sensor doesn't seem to be the cause.
I'd changed the defective (water corrosion due to interior cleaning by a cleaning service provider) climate control modul (incl. SDD diagnostic tests), the defrost flap is now running but this wasn't the cause, too.
But my "repair project" is still running...
Did you check the signal wire (white blue) / it's PWM control signal at the fan control module on the fan assembly?
Old Jun 3, 2022 | 02:45 AM
faridz's Avatar
Default Fan running at high speed
Thanks for your reply. The culprit was the new control module. I replaced the whole fan assembly this time and all was resolved.
Old Jul 5, 2022 | 05:44 AM
catfondler's Avatar
What "new control module"? You'd replaced the original Fan Control Module to a new one? A module from China?
And then you'd replaced the wohole fan assembly? (A new one? Bougt from Jaguar/JLR?)
Diddion
Jul 24, 2017 08:14 AM
kulddy
Aug 15, 2015 05:12 PM
slideshow801
May 12, 2012 12:29 PM
Simprof
Nov 15, 2010 05:36 PM
vennala@lycos.com
May 20, 2008 06:10 AM
