Rear brake caliper bolts
I had just replaced all my rotors and pads but the caliper mounting bolt I took off was not in usable condition, does anyone know which bolt size that is for a jaguar Xtype 2005 3.0. Rear I only need the bolt not the guide pins. Thanks
The rear brake caliper bolt part #'s are C2S9418, C2S46549 and C2S15593, depending on the VIN and top or bottom bolt.
brit-car.co.uk has pictures along side a CM ruler:
C2S46549 | BOLT | Jaguar | | Britcar (UK) Ltd
C2S15593 | SCREW-FLANGE | Jaguar | | Britcar (UK) Ltd
If you have one good bolt, most autoparts stores can match the size and thread. Avoid generic hardware stores bolts, e.g., low carbon Grade 2. For brakes you want automotive grade, hardened steel bolts, e.g., Grade 8+ or Class 10.9+.
Tar
Sep 6, 2015 11:24 AM
philwarner
Sep 5, 2015 10:05 AM
