Rear caliper bracket issue
Old Sep 18, 2015 | 08:30 AM
iownme's Avatar
Default Rear caliper bracket issue
When i did a brake lube job a couple months ago i noticed that the slide pin with the rubber sleeve was in the bottom hole on one caliper and the top hole on the other caliper. I reassembled as i found it.
Yesterday while all disassembled i noticed the top slide pin (rubber sleeved) on the passenger side would not move.
In fact i was unable to move it in or out at all.. It turns no problem.
Can i assume the pins on this side are wrong way around?
And if so how can i get that top pin out??
Im quite sure there is not a corrosion issue
Old Sep 18, 2015 | 12:06 PM
dwclapp's Avatar
iownme: The caliper pin w/ the rubber sleeve is in the top position, front & rear, per JEPC drawings. Whether that's critical or trivial, I don't know. But it is important that the brake pad housing slide freely on the pins.
If you must damage the stuck pin to removing it, dr dome can probably provide a replacement - he parts out X-Types at reasonable prices.
Use silicone grease on these pins. Petroleum grease degrades at hot brake temperatures, and it can weaken & swell the rubber sleeve and dust covers.
Perhaps the pin is stuck because a former owner used petroleum grease by mistake, and the rubber sleeve is now swollen in place? Just a guess.
Old Sep 19, 2015 | 08:15 AM
iownme's Avatar
[IMG]https://cimg2.ibsrv.net/gimg/
www.jaguarforums.com-vbulletin/390x471/80-jagaur_x_type_rear_brakes_8a527a1311c05084fe12ae51 be7c02dfa2e76f54.png[/IMG]
It was me that lubed them last time using permatex ultra brake caliper lube (rubber safe)
I'm going to take the caliper mount off today and try harder.. Lol
Old Sep 19, 2015 | 08:52 PM
Dr dome's Avatar
If you need parts I have both sides. Let me know,
The Dr!
Old Sep 20, 2015 | 10:31 AM
iownme's Avatar
The Dr!
Thanks Dr!
I removed the bracket from the car so i could get better pulling power.
With vice grips attached to the top of the pin i was able to pull to pin out...it took a lot of pulling power to get it out.
The pic attached shows what i found to be the problem.
Rubber sleeve already ordered!
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
obwoodie
Sep 3, 2015 07:45 PM
Dallas XK8
Sep 3, 2015 12:17 PM
OkieTim
Sep 2, 2015 12:48 PM
