rear lights
Old Nov 14, 2013 | 03:42 PM
Thermo's Avatar
Veteran: Navy
Finlay, I need to correct what I said before. Like was pointed out, the correct fuse rating for fuses F29 and F30 should be 20 amp. I deal with too many vehicles and trying to keep all the diagrams at the tip of my mind can be confusing. Yes, I have some key diagrams committed to memory. It is a side effect of what I do for a living.
Old Nov 18, 2013 | 12:47 PM
finlayc's Avatar
Many thanks for all your advice and help. I am going with 10amp. I will keep you posted if any problems arise.
Best regards.
Chris.
Old Feb 26, 2014 | 10:19 PM
AlexRendon's Avatar
Default issue with my tail light
Myleft tail light stopped working. It only works when i break. I was wondering if that can be an issue with a fuse? if so, where can i find and replace it? Can you please help me?
Old Feb 26, 2014 | 10:20 PM
AlexRendon's Avatar
by the way, i have a 2005 jaguar x type 3.0.
Old Feb 27, 2014 | 02:54 AM
Thermo's Avatar
Veteran: Navy
Alex, first off, welcome to the Forums. I think you will find lots of useful information here. You will also find out that we are a very friendly group here. But, part of that is we know each other. So, please stop by the New Member Section and introduce yourself. We get to meet you and you get to see who makes this place what it is.
As for your problem, odds are, you are looking at a bad plug on the left tail light. You will need to access the plug and then remove it from the socket. You will want to look at both ends and make sure that all the connections are silver in color. They should not be rusty or a dull, dingy gray color. if they are, you will probably need to take a scribe or other small tool and clean up the contacts.
99xk8guy
Sep 29, 2025 10:51 PM
mbergen
Oct 23, 2019 10:26 PM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
