Rear orr side brake caliper
Old Jan 12, 2014 | 06:44 AM
neil.rush's Avatar
Default Rear orr side brake caliper
Hi,i am in need off a rear off side caliper,i have my mot tomorrow and the hand brake part is sticking on,its not the cables,i live in Ashford kent,can any one help,i can pay for the item,thanks for any help
Old Jan 12, 2014 | 08:06 AM
Thermo's Avatar
Veteran: Navy
Neil, you can fix this yourself. It is the shaft that runs from the e-brake lever into the caliper. If you remove the lever, you can then remove a rubber boot that surrounds the shaft. From there, you can use some WD-40 or other rust removing fluid and squirt it down the side of the shaft. With a little bit of work, it will allow you to get past MOT. To fix it long term, you can then either get a new caliper or you can spend about $30 USD to get a 14mm pentasocket (yes, a 5 sided socket) and a caliper rebuild kit and tear the caliper down yourself. It is pretty easy. Then you can remove that shaft completely and clean up the surfaces to make things run perfect again.
If you want more info on the rebuild, check out: https://www.jaguarforums.com/forum/x...fix-1-a-73065/
Old Jan 12, 2014 | 08:17 AM
neil.rush's Avatar
Thank you for your help,the link is perfect,thank you
99xk8guy
Sep 29, 2025 10:51 PM
PMKimpton
Aug 3, 2019 08:22 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
philwarner
Sep 5, 2015 10:05 AM
obwoodie
Sep 3, 2015 07:45 PM
