Rear Shocks
Old Jul 6, 2011 | 11:23 AM
compdude97's Avatar
Default Rear Shocks
My rear shocks are blown, so I just bought a new pair of Bilsteins to put in. I have never done shocks on my X before, how difficult are the upper bolts and are there any tips or tricks I should know?
Old Jul 7, 2011 | 08:20 AM
daxter1987's Avatar
For what I read in the Jaguar Technical Information (I'm a Jaguar Tech) it doesn't seem so bad. The top bolts seem to be aiming down. Here is the procedure:
Removal:
1)Raise and support the vehicle.
2)Detach the damper.
3)Remove the damper.
Installation
1)Install the damper.
2)Attach the damper.
3)Tighten to 25 Nm.
4)Tighten to 130 Nm.
Here is a pick of the top bolts Good luck! and please visit my blog on the link below!
Car Articles
Old Jul 7, 2011 | 08:27 AM
pab's Avatar
pab
Search the thread, Luke...
I think someone said that the top bolts are rust-prone and may present a challenge for removal. I believe they said that if they break you may be in
trouble since they are welded in.
Or somethin like that...
Jaguar - it's not an automobile, it's a Motorcar
Old Jul 8, 2011 | 09:46 AM
daxter1987's Avatar
By the look of the pic in the prodecure those look s like studs and nuts not bolts, so make sure you spray them with some rost off or some similar solvent.
Old Jul 11, 2011 | 02:30 PM
compdude97's Avatar
I plan to spray the hell out of it with PB Blaster before I do anything.
Old Jul 11, 2011 | 03:57 PM
Tony_H's Avatar
I did mine. With the right socket, extension and U-joint...easy.
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
KarimPA
Sep 12, 2015 08:15 AM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
Busa R
Sep 3, 2015 05:01 PM
