Rear Suspension Problems..Rubbing BAD
Old Jan 23, 2007 | 11:09 PM
Default RE: Rear Suspension Problems..Rubbing BAD
ORIGINAL: racerx82
nice, but i'm sure you got some rub marks....get your fenders rolled and you should be good to go....
rim offset on a jag is 46 or 48 i think
C'mon racer - you think? You're sposed to be the sum of all knowledge! Lettin the side down man.....Give the correct info plz.
Jim C
Old Jan 23, 2007 | 11:20 PM
racerx82's Avatar
My bad.....sorry..rim offset is 48mm, bolt pattern is 5-108
Old Jan 23, 2007 | 11:23 PM
racerx82's Avatar
FYI additional info
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.Zero OffsetThe hub mounting surface is even with the centerline of the wheel.PositiveThe hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.NegativeThe hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.[/align]
Old Jan 23, 2007 | 11:27 PM
racerx82's Avatar
Old Jan 23, 2007 | 11:29 PM
Way to go racer
Jim C
Old Jan 23, 2007 | 11:33 PM
racerx82's Avatar
that was too much work for me in one day....i need more beer..
Old Jan 23, 2007 | 11:54 PM
Try goin onto spirits racer...........you'll get the desired result much quicker...........rofl
Jim C
Old Jan 24, 2007 | 11:46 PM
  #28
racerx82's Avatar
no, then i have a headache in the morning and can't do any work on my computer.....lol beer is the way to go!
Old Jan 29, 2007 | 07:13 PM
aquill1's Avatar
I know why racer hasn't had the usual comments is because all he thinks about anymore is beer!
Old Jan 29, 2007 | 09:17 PM
  #30
BuckMR2's Avatar
That reimnds me I'll have to start somemore homebrew off this week
Old Jan 30, 2007 | 06:22 PM
  #32
aquill1's Avatar
Thats what I guessed it was but than the problem I have is why would jag put a 225/45zr17 on the car stock when even these rub? Wonder if they have noticed this problem?
Old Jan 31, 2007 | 01:01 AM
  #34
IronCobra's Avatar
I believe they are +38 offset.
Old Jan 31, 2007 | 01:22 AM
  #35
racerx82's Avatar
lol....must be the weather...lol
Old Jan 31, 2007 | 08:24 PM
  #36
Jeez,,,,,,,,,somebodys havin a bad day.........lol
Jim C
PMKimpton
Aug 3, 2019 08:22 PM
02jagstype
Sep 4, 2015 08:20 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
