rear trailing arm bush ?
Old Nov 5, 2017 | 01:03 AM
paulkath's Avatar
Default rear trailing arm bush ?
my 09 x type failed MOT on rear trailing arm bushes, ?? which exactly is trailing arm ? is it an easy job
Old Nov 5, 2017 | 11:33 AM
avern1's Avatar
I am not sure what the MOT is refer to as trailing arms, but attached is the parts blow up for the rear suspension.
There are bushings located at piece numbers 1, 3, 6, 7, 9, and 10. Most likely they are calling out the bushings in piece 1.
Our forum sponsor SNG Barratt can provide them.
Old Nov 5, 2017 | 10:14 PM
Dell Gailey's Avatar
A trailing-arm suspension, sometimes referred as trailing-link is a vehicle suspension design in which one or more arms (or "links") are connected between (and perpendicular to and forward of) the axle and a pivot point (located on thechassis of a motor vehicle). It is typically used on the rear axle of a motor vehicle.
A trailing arm design can also be used in an independent suspensionarrangement. Each wheel hub is located only by a large, roughly triangular arm that pivots at one point, ahead of the wheel. Seen from the side, this arm is roughly parallel to the ground, with the angle changing based on road irregularities.
JAGUAR OEM 02-08 X-Type Rear-Trailing Control Arm C2S49745
Old Nov 5, 2017 | 10:16 PM
Old Nov 5, 2017 | 10:27 PM
Also called a rear stub axle or read hub carrier
Jamil
Oct 12, 2016 04:01 PM
Blondie 1
Oct 1, 2016 01:02 PM
bojangles
Oct 19, 2009 05:12 PM
IronCobra06
Dec 3, 2006 07:29 PM
