rear wheel well inner splash shield
Old Jul 29, 2009 | 11:43 AM
Rich W's Avatar
Default rear wheel well inner splash shield
I seem to be missing the right inner wheel well splash shield. The left side seems to have a full splash shield - inner fender, the right does not. Also the right side end of the rear bumper cover is loose and not attached to anything!
What should be in there that's missing. Any parts diagrams available on the forum (searched, no luck).
Thanks,
Rich
Old Jul 29, 2009 | 01:31 PM
BuckMR2's Avatar
Rich, both bumpers should have guides one each side at the front and one each side at the back which attach them to the body panels (L and R wings at the front and L and R 1/4 panels at the back)
Give your dealer your reg or last 6 of your chassis and get them to fax a pic of the back bumper to you so you can see them.Its concerning that one is missing/damaged as they dont just come off unless physically removed (bumper needs to be off to do this) or damaged (eg snapped) eg by an accident.
I did have a pdf doc with pics and part numbers for lots of parts but since my last PC crashed lost all the info...trying to get it again
Old Jul 29, 2009 | 11:01 PM
Disco stu55's Avatar
Okay, i had a simalr problem a couple months back, hit and run long story, but i tore out my splash sheild and my splash guard and my front bumper is messed. The spalsh shield i think has to be fixed becuase it gets gunked up pretty good. There should be mounting points, two at the were front end ( where the the sheild ends) and 1 at the back ( where the shield ends) if there not there you may have damaged then and need to replace another component ( like i have too) depending on whether its missing in the front or back? theres also a few that go around the the outside ( open end where the wheel goes) that attach tot he fender, make sure those mounts are there aswell. And there might be some around the axle/behind the center of the wheel. Im not sure about those ones. There quite fragile if you ask me, when i ordered mine i let it sit and it started to warp, over time it get very hard and brittle and tends to crack easy and break.
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
innzane
Sep 2, 2015 10:08 AM
