reccomended oil grade for x-type 2006 ??
Old Apr 4, 2010 | 08:08 AM
Thermo's Avatar
Veteran: Navy
Bill, I know this might sound funny, but look at the top of the oil fill cap. The recommended weight from Jag should be printed right there. You will find that running either 5W-30 or 5W-20 will be recommended. For the summer I would say run the 5W-30. During the winter, may be advantageous to run the 5W-20 since it is slightly thinner.
Doing a quick look, I can't see whether the 0w-40 is a synthetic, mix, or not (since it isn't saying, I would have to guess it is a standard dino oil-ie, non synthetic). You shouldn't have any issues running this oil in your car. What you may see is a slight drop in your gas mileage due to the oil pump having to work a little harder to pump the thicker oil. We are not talking a major drop, but a few tenths is not uncommon. This is the reason why a lot of the manufacturers are going with the thinnest oil that they can. Trying to squeeze each MPG that they can out of the engine. If in doubt, check out a website called "Bob is the Oil Guy". This guy knows more about oil and what not than you could ever think of knowing. You should find all the details you want.
Old Apr 4, 2010 | 12:46 PM
BuckMR2's Avatar
Its Castrol Magnatec 5w-30
In the handbook it says Jaguar recommend Castrol
On the Castrol website if you enter your cars registration number (UK only) it brings up the oils for the different parts of your car and the capacities.
Alternatively you can download the handbook online from
http://www.ownerinfo.jaguar.com/extf...prod/index.jsp
Edit
Just read the USA handbook for MY2006.25MY and it says
SAE Viscosity Rating
- For climates ranging from -30°C ( -22°F) to +50°C
(+122°F), the following oil viscosities may be used:
0W-30
5W-30 (preferred)
0W-40
5W-40
Note: For maximum fuel economy, 5W-30 oil is recommended.
It is recommended that the oil level is topped up using oil of the same viscosity.
If you are unsure which oil viscosity is used in your car, your Jaguar Dealer will be able to advise.
Old Apr 9, 2012 | 10:30 PM
Jamesjr576's Avatar
Very good Fact and Myth article from Castrol Oil... Def should check this out.
Castrol USA - Can You Handle the Truth about Synthetic Oil?
Scarecrow
Mar 28, 2016 03:17 AM
adam699
Sep 12, 2015 05:32 PM
Busa R
Sep 10, 2015 07:28 PM
SCMike
Sep 9, 2015 09:30 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
