Repair Bill WTF?!!
Old Dec 12, 2013 | 10:12 AM
mygirlsjag's Avatar
Default Repair Bill WTF?!!
2206 x-type:
Just got a call from the service manager at the local dealership. Took the car in for a check engine light. Along with a check valve and leaking vacuum line they found a coolant leak between the reservoir and radiator; also are "suggesting" we replace the upper radiator hose which is "swollen".... should that cost $860.02???
I'm not a certified mechanic but have some dealings under a hood. I have replaced radiators, water pumps, tensioner pulleys, power steering gear boxes and done minor repairs on every other vehicle I have ever owned. From Fords to Jeeps to Hondas. Is a Jag really that much different that a normal $17.00 part should cost over $800 to repair? Or am I just getting royally screwed because of the brand name?
Somebody help
Old Dec 12, 2013 | 10:33 AM
Alfadude's Avatar
Sorry to hear you are having issues. From your description it sounds like you could do this yourself. Search a thread called: "replacing top rad hose and thermostat housing". That will explain what is all involved so you know what you are up against. Sounds like it might be a pain, but not difficult. You can decide yourself if you want to tackle it.
A Jag does have its quirks that is unique to the model itself, but for the most part it isn't any different than most cars. Pretty much anything that has gone wrong with these cars has been discussed here and fixed. From the sound of your vacuum leaks those were very simple to address and you could have done those yourself as well. Surf around here when you have a problem and you will be surprised at the wealth of information and friendly people willing to help.
Good luck!
Old Dec 12, 2013 | 11:43 AM
Justink201's Avatar
Its not the parts that cost a lot to have replaced at a dealership, its the labor costs. I know the dealer around here charges 135 an hour...
Old Dec 12, 2013 | 12:25 PM
Sounds about right re the labour costs.
My local Audi dealer takes £125 per hour, thats about $205.....a fair ole chunk of change
Old Dec 12, 2013 | 01:15 PM
joycesjag's Avatar
mygirlsjag, as mentioned above you sound like you know the business end of a screwdriver, these vehicles are easily DIY'ed believe it or not.
If you don't feel like wrenching send fellow member Jon89 here a PM and he has a few places in Raleigh he would recommend other than your dealers there.
bdboyle
Sep 16, 2019 05:58 PM
Woznaldo
Sep 26, 2015 11:02 AM
reb1999
Sep 26, 2015 08:41 AM
redgear
Sep 26, 2015 07:21 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
