Replace front lower control arm
Old May 14, 2017 | 11:13 AM
Jag4's Avatar
Default Replace front lower control arm
Hello forum,
My mechanic tells me he will have to lower the front chassis to replace the lower arm. I don't see that as a requirement when I am looking at the workshop manual but what do I know.
I know lowering the chassis takes time but is it really necessary to replace the lower control arm?
Old May 14, 2017 | 12:46 PM
David vince's Avatar
Unfortunately yes, to remove the rear bolts the subframe has to be lowered to give clearance to get them out.
David
Old May 14, 2017 | 01:04 PM
swingwing's Avatar
If you don't lower the subframe you risk breaking open the large oil-filled bushing on the control arm. I have the t-shirt.
Attached Thumbnails Replace front lower control arm-front-lower-cont-arm.jpg
Old May 14, 2017 | 01:57 PM
motorcarman's Avatar
When reassembling, you can do what VW did to the same control arm setup with New Beetles and Jettas, INSTALL THE BOLT POINTING UP, with nut on top.
Next time someone will thank you.
bob
Old May 14, 2017 | 03:17 PM
Jag4's Avatar
bob
Good one - thanks motorcarman!
