Replaced oxygen sensor, but same codes appear
Old Jan 10, 2019 | 05:09 PM
Sean Lurie's Avatar
Default Replaced oxygen sensor, but same codes appear
Hi Guys,
I need some help. Recently my Jag started using more fuel than usual and smelt fumes after stopping in the garage. Turns out I had an Oxygen Sensor problem with codes P0051 and P0052. The car was already at 106,000km so decided to replace the sensor. Bought a proper Denso and made sure I got the the right one. To my dismay the codes appeared again after rescanning the ECU and symptoms still showed up. Checked the immediate connections points and wires. Everything seems to be ok.
I'd be glad to hear your thoughts and suggestions on what to check next. Could an exhaust leak throw these codes?
Cheers,
Sean
Old Jan 11, 2019 | 01:25 AM
Steve M's Avatar
Have you replaced the correct sensor?
This might be the wrong diagram but there is more than 1 sensor.
Old Jan 11, 2019 | 04:27 AM
Sean Lurie's Avatar
Hi Steve,
Yes I'm pretty sure it was the right sensor (upstream sensor 1, bank 2.)
Old Jan 11, 2019 | 11:17 AM
Dell Gailey's Avatar
Bank 2 upstream: Denso 234-9029
Old Jan 11, 2019 | 01:52 PM
JagV8's Avatar
I suppose one of: changed the wrong one, put the wrong kind in, it's a wiring/fuse fault, and so on.
harlock
Oct 13, 2018 09:39 PM
kstevusa
Aug 25, 2016 05:03 AM
guyslp
Dec 25, 2013 02:50 PM
JEMCAM
XJ40 ( XJ81 )
Jul 8, 2010 07:39 PM
