Replacement Lug Nuts
Old Sep 6, 2014 | 10:50 PM
wa3ra's Avatar
Default Replacement Lug Nuts
After being driven more than a half-a-bubble off plumb trying to figure out what was ticking, I discovered it to be the less-than-stellar two piece lug nuts that Jaguar decided to be suitable for our cars. The covers are easily damaged, and more than a little likely to come apart, especially when torqued down by ham-fisted tire techs with their impact guns set on 'kill'.
Shopping for replacements was not so thrilling; an OEM set can cost $200 or better, a decent replacement aftermarket set is available from only one supplier, and even on eBay or Amazon, still $100!
Why? They are simply 12mm x 1.5 pitch mag seat lug nuts, what is so unusual about them?
Here it is: The caps are 19mm.
That is the ONLY thing keeping you from being able to find a suitable replacement.
The solution? Break out the mic and the vernier, measure them up, and find a suitable replacement. What fits? Mitsubishi, Chrysler Sebring, Isuzu, Lexus, Toyota, there are millions of 'em. Dorman 6111-117 is the single part number.
Best match, high-quality single piece lugs are for the Toyota Scion, hunt around and you can find a full set under $30US.
Physical differences: 37mm height versus 44 for the stock, and a smaller washer at the seat, since the new nut doesn't need to be spaced to sit right. They seat perfectly, don't stick out as far, look a little 'beefier' in the wheel, and won't come apart, since they are one piece.
Here is the main difference: the nuts are 21mm. I suggest getting a half-inch breaker bar, a three inch extension, and a 21mm deep impact socket for your trunk, and throw away that Ford spec'ed piece of junk lug wrench in your spare well. The only thing that is good for is spinning the caps off the factory lugs anyway.
Just a reminder: factory recommended torque on the lugs is 76 lb.ft. dry for the alloys.
Old Sep 7, 2014 | 02:20 AM
santer's Avatar
Changed mine for Toyota nuts and also these
Alloy Wheel Locking Nuts for Toyota Celica T180 T200 T230 1989 07 Lug Bolts 6A | eBay
Old Sep 7, 2014 | 07:17 AM
dopey's Avatar
thanks for sharing that info, I've got a set of Mitsubishi nuts that look the same and wondered if they would fit the S-Type but haven't got around to trying them yet.
Old Sep 7, 2014 | 08:28 AM
wa3ra's Avatar
Yes, they do fit the S-type, as well!
Old Sep 7, 2014 | 12:26 PM
flyrr100's Avatar
Check these out...
Cragar Style Mag Lug Nut 12x1.5
Old Sep 7, 2014 | 01:22 PM
wa3ra's Avatar
The thread pitch and depth are wrong on those, and you'd still need the washers.
That was one of the potentials that I looked at.
Old Sep 7, 2014 | 08:54 PM
zackhord's Avatar
I had to replace one lug nut on my xtype. I ended up going with one from a Lincoln LS. Its the same thread pitch and socket size. The only difference is the very end of it. Fits perfect though. I think I spent $2 on one at my local auto zone. $2 x 20 =$40 for a set. I can live with the different look to save $160 over factory.
Old Sep 9, 2014 | 03:02 PM
WayneCountyBill's Avatar
Default Same Situation
I purchased spare lug nuts for my 2003 X-Type 2.5. I purchased them at a Jaguar dealer and they were $4/ea. I purchased them in November of 2010. I also purchased the special socket for removal. Hope this helps. Bill in Wayne County OH
Old Sep 10, 2014 | 04:01 PM
quinnjere's Avatar
Where did you find those scion lugs I would like to order those same ones
Old Sep 10, 2014 | 05:10 PM
wa3ra's Avatar
Here's one of the eBay sellers, but shop around...
Chrome Factory OEM Toyota Lexus Scion Style Wheel Lug Nuts Mag Seat Qty 20 | eBay
Old Sep 10, 2014 | 05:21 PM
SNG Barratt USA's Avatar
Former Sponsor
Ours:
www.sngbarratt.com/PartSearchResults.aspx?partno=C2C35294010
$3.56 Minus your 10% JF discount. Would be 1 week if ordered. Genuine Item. Feel free to PM me for any details on these.
Old Sep 11, 2014 | 07:35 AM
pab's Avatar
pab
And make sure to get a new lug wrench since the factory one won't fit. I got the Gorilla wrench.
Jaguar - it's not an automobile, it's a Motorcar
Old Sep 11, 2014 | 09:01 AM
boobea's Avatar
Exclamation
Believe it or not, COSTCO tire has many different size nuts. They look good, and are really a good buy. Just a thought
Old Sep 11, 2014 | 11:23 AM
wa3ra's Avatar
I'll bet SNG Barratt's are a lot better quality that the eBay types.
...I can't use them because we are away so much that we can't usually be there to sign for the package
Old Sep 11, 2014 | 11:55 AM
Former Sponsor
Ours are Genuine Factory originals
We can leave parcels without signature, and/or send to hotels/family etc etc upon request!
Old Sep 11, 2014 | 01:06 PM
pab's Avatar
pab
Which are, unfortunately, the ones we all need to replace. :-(
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Sep 11, 2014 | 02:43 PM
Former Sponsor
Allow me to re-phrase. They are the 'new version' factory originals.
Old Sep 11, 2014 | 08:49 PM
wa3ra's Avatar
One-piece?
Forcedair1
Sep 8, 2025 01:57 PM
sogood
Sep 15, 2015 07:35 AM
KarimPA
Sep 12, 2015 08:15 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
KarimPA
Sep 3, 2015 07:32 PM
