Rim question please help!
Old Aug 8, 2009 | 08:40 PM
Thermo's Avatar
Veteran: Navy
jwatts, no, you can not use those rims. Your Jag uses a 5x108 (not a 5x100) bolt pattern. It may be possible that you can get the rims and then take them to a machine shop and they can redrill the holes for you, but I think you are going to find that most shops are going to be hessitant to do something like that.
Old Aug 8, 2009 | 10:24 PM
ghettomike's Avatar
I have noticed it is hard to find rims for the jag...at least in canada it is.
Anyone know the offset?
Old Aug 9, 2009 | 07:00 AM
Thermo's Avatar
Veteran: Navy
Mike, the offset for the factory 17x7.5" rims is +40mm. But, if you change the rim width, then the offset is going to need to change as the offset is a function of rim width. So, as you go with a narrower rim, you will need more positive offset, as you go wider, you will need less positive offset. As a rule of thumb, for every half inch you change the rim width, the offset needs to change by 7mm. This is needed to be done to maintain the proper geometry between the center of the rim (side to side) and the center of the wheel bearings.
if you need more info on this, let me know.
Old Aug 9, 2009 | 11:05 AM
Disco stu55's Avatar
Im just going with kal tire when the time comes mike, or unless i find something better.
Old Aug 10, 2009 | 08:55 AM
ghettomike's Avatar
Where is kal tire? I have heard of them...
Old Aug 10, 2009 | 09:24 AM
It everywhere, or fountain tire, can't belive u've never heard of them
Old Aug 10, 2009 | 10:57 AM
The Chris X's Avatar
Ordered my Voxx MG's from Discount Tire Direct online. Tirerack.com also carries several choices.
Old Aug 10, 2009 | 11:10 PM
thanx a ton dude, that website is really good
Old Aug 11, 2009 | 08:20 AM
Here's what they look like - 17 inch with 225/45's
DrTripp
Mar 22, 2020 09:33 AM
slojotaa
Oct 16, 2019 10:22 AM
lickahotskillet
Oct 18, 2015 09:51 AM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
