Road Noise
Old Jan 17, 2012 | 07:57 AM
JagYour's Avatar
Default Road Noise
I have the oddest metal on metal sound. Going at least 50 km/h per hour I have loud road noise for the first time ever. It is really loud when talking a right hand turn but no change when I take a left hand turn. What really strikes me as odd is that it appears to be coming from the rear. I have greased the shaft in the past and have a wheel bearing replaced but it does not sound like that. Tires are inflated properly with no signs of tire wear. Any thoughts?
Old Jan 17, 2012 | 10:58 AM
stevemilleresq's Avatar
Could be brakes, the warning sensor that your pads are near the end of their life makes a metallic sound.
Old Jan 17, 2012 | 11:12 AM
rothe's Avatar
Have you taken the wheels off and *inspected* anything back there yet?
Old Jan 17, 2012 | 01:48 PM
JagYour's Avatar
Never thought about the brakes as it only happens when I turn right. Will consider that though. Does the warning sensor appear as a light on the dash or is it just a metallic sound? I have not had the wheel off yet just a visual inspection of the outside and I performed some different driving patterns to try and pinpoint the issue.
Old Jan 18, 2012 | 07:28 AM
I have a 2002 and there was no light when the brakes needed to be done, just a scratchy metallic sound. Does the sound stop when you step on the brake pedal?
Old Jan 18, 2012 | 05:14 PM
JagXster's Avatar
sounds like a wheel bearing
Old Jan 19, 2012 | 07:03 AM
Wheel bearing is a good possibility if the sound doesn't stop when you step on the brakes.
Old Jan 22, 2012 | 05:31 AM
JagYour's Avatar
Sound does not stop when I use the brakes. A bad wheel bearing is a definite possibility. What confuses me is that it is much more pronounced on a right turn at speed.
Old Jan 22, 2012 | 07:08 PM
JagXster's Avatar
typical sign of a bad wheel bearing. If you go hard left it will silence the noise.
XJ8JR
26
Aug 8, 2020 09:38 PM
Lannyl81
Sep 20, 2015 08:56 PM
Horus
Sep 18, 2015 05:39 AM
sawduster
Sep 11, 2015 10:02 PM
raulan
Sep 10, 2015 12:43 PM
