rough idle when cold, now missfires all the time
Old Aug 10, 2012 | 03:49 AM
amcastro1's Avatar
Default rough idle when cold, now missfires all the time
Hello my Friends.
starting to think to give up and to throw away my Jag.
Maybe one of you can shed some light and make me change my mind, but I´m starting to think Jag never more (I have a 94 mazda xedos 6 with 0 problems).
Well enough crying My problem is as follows:
It started with the my 3.0 X-type rough idling when cold (it was probably misfiring, but at the time I didn,t know that).
After a while it ran great. After some time this started happening even with the car "hot" while running but it was very rare. Now it is ALL the time. I diagnosed the car and at first it showed cylinder 5 missfiring, now it shows 1 and 3 misfiring.
After some forum search I noticed that it appeared it was as a common problem, so I replaced the IMT rings, the manifold seals, the crankcase hose, the brave valve tube, but no change
I would take it to the dealer but I realized a while ago that they know less than the forum experts and they charge a
lot more
So any inputs???
Old Aug 10, 2012 | 07:23 AM
Sorry to hear about your issues.
Post all the codes here (actual codes and not the descriptions) and you should get help with troubleshooting the misfire.
Old Aug 10, 2012 | 07:30 AM
abonano's Avatar
+1 on getting the actual codes posted - How many miles on the car? With the above work were the cam covers and spark well rubber gaskets changed? Just curious as if you have seeping oil into the spark wells this condition will certainly fry a new ignition coil very quickly. Let us know - Thanks!
Old Aug 10, 2012 | 08:37 AM
amcastro1's Avatar
Hi,
Thanks for your interest in my problem.
The codes are: P1313 and P0300 P0301 P0303
We can rule out spark plugs and coils (all tested fine and were replaced at 124000Km ). Also no oil on the wells.
I think that it can really be a vacuum leak because I do hear a hissing sound but I can not "see" where it is, but I think I replaced everything that should be replaced to avoid vacum leaks..... I´m truly lost
my Jag has 130000 Km on the clock.
Old Aug 10, 2012 | 10:14 AM
I've extracted the Jaguar DTC definitions and possible causes to get you started:
JAGUAR X Type - DTC.pdf
You don't have sufficient posts to be able to open this PDF on the forum so I've put it on my MediaFire account. You can download it using this link:
Free Cloud Storage - MediaFire
The possible causes of your DTC's are:
cylinder compression low
worn camshaft / broke valve spring(s)
fuel delivery pressure low / high
fuel injectors restricted / leaking
fuel injectors continuously open
fuel contamination
fuel injector circuit faults (injector DTC's also flagged)
spark plug failure / fouled / incorrect gap
ECM to ignition coil primary circuit fault (cylinder misfire detected DTC also flagged)
ignition coil failure
I'll stand aside and let the X-Type experts jump in!
Old Aug 14, 2012 | 09:16 AM
amcastro1's Avatar
Hi, thanks for your reply and for the codes (I have them already but thanks anyway).
The strange thing is that my car also runs on LPG, and on LPG it works great, so you think that I can rule out a vacum leak???
Working good on LPG and not on Petrol is in fact odd.
Any thoughts
Regards
SD96XJ6L
Jan 12, 2022 04:30 AM
PMKimpton
Aug 3, 2019 08:22 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
