Rough start up
Old Feb 3, 2021 | 12:04 PM
ryarb1758's Avatar
Default Rough start up
My 2002 X-Type 3.0 AWD has begun giving me a rough start up. When I start it on cold mornings it idles very rough almost going dead but does continue to run until it warms up considerably then runs smooth, any suggestions where I should start to track the problem?
Old Feb 4, 2021 | 02:48 AM
Originally Posted by ryarb1758
..... any suggestions where I should start to track the problem?
YES - in our X-Type forum.
I've moved your question for advice from members with the same model. My first thoughts from the cold start / rough warm up / then smooth running description would be a faulty ECT (Engine Coolant Temperature) sensor.
Old Feb 4, 2021 | 07:04 AM
TonyJ1977's Avatar
Usually it’s one of two things. The engine coolant sensor or the crank sensor. I fault this for two winters before finally finding out mine was the crank sensor. Both parts are easy to change and very reasonable priced
Old Feb 4, 2021 | 08:38 AM
RudyF6's Avatar
Mine was a 2.5, but exactly the same behavior with a split PCV hose.
Old Feb 4, 2021 | 01:43 PM
ryarb1758's Avatar
Thanks Folks, gives me great starting points.
Old Feb 9, 2021 | 11:20 PM
Mr rx-7 tt's Avatar
Mine was the IMT O' Rings.
https://www.jaguarforums.com/forum/x...-p0174-239618/
mystype04
Apr 11, 2019 08:46 AM
CsaeyHall20
Dec 8, 2018 10:34 PM
Dan R
Dec 20, 2017 10:48 AM
xjrwithproblems
Nov 9, 2013 02:56 PM
EuroCarz99
Jan 27, 2009 04:02 PM
