Sat Nav - 2007 X-Type
Old Jun 24, 2015 | 04:06 PM
tablesawjock's Avatar
Angry Sat Nav - 2007 X-Type
Hi guys new to this not sure if any one can help I have a 57 plate xtype non sat nav but it has the phone module fitted I purchased a complete sat nav including wiring looms to upgrade when I took the radio climate unit out today to swap them the main power plug from the dash will not fit the sat nav unit it seems to be to big hense to say there is no power at the unit can I purchase a adatpter for this dont understand why they would change a simple connection the unit I purchased also came from a 07 xtype thats why I bought it but what do I know thought that would make it easier to change need guidance thanks
Old Jun 24, 2015 | 04:21 PM
Welcome to the forum tablesawjock,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Jun 24, 2015 | 09:11 PM
dennis black's Avatar
20 Year Member
do you have a pic of exactly what you have ,
Old Jun 25, 2015 | 07:23 AM
euanT's Avatar
There should be two large multi-plugs, one go's into the back of the CD unit the other go's into the screen unit!!
Attached Thumbnails Sat Nav - 2007 X-Type-img_1978.jpg   Sat Nav - 2007 X-Type-headunit-wiring.jpg
Old Jun 25, 2015 | 10:53 AM
Hi guys I put pics of what I have in a album not sure
how to put them up yet still trying to use the site thanks
for all help the black plug that comes from behind the dash
I take it supplies power is to large will not fit the climate
control unit plugs in fine but has a number of leads with
plugs that I dont know where they go
Old Jun 26, 2015 | 06:59 AM
Default re satnav x type
I I have made a album in my status with what I have with the satnav the car already has the
phone but I am unsure about where the cables go the power lead fom the old unit is to large
for the satnav unit can you get an adapter or is it useless can any one help
Old Jun 26, 2015 | 12:08 PM
euanT's Avatar
The two plugs required are the same shape, the other two slimmer ones are not for the SatNav unit! The second of my pictures just shows the cables going into the screen unit, it is the same shape as the one going to the CD unit!!
File Type: pdf
Old Jun 26, 2015 | 02:06 PM
x_type_lpg's Avatar
you you have manual climate control ( 3 big knobs) or auto climate control ( one knob next to lcd display)?
if you have auto climate control then the two cables from the back of the top unit go to the rccm module. the radio plug will go to the new radio under the touch screen, the touch screen will have a new plug that connects to the dvd unit in the rear via the front passenger footwell.
I can post some pics of the plugs on the end of the looms if that helps.
if you have the manual climate control then its a bigger job changing over to use a touch screen.
Old Jun 26, 2015 | 02:20 PM
Hi it is auto control the unit that came out has 3 cables two at the bottom where the cd is
the white plugs into the new climate control but the black one is two big and it will not fit the touch screen the black one comes from the dash board the steering has all the controls on it for phone ect I think I will need to get someone to conect it up dont mind paying not sure where the cables on the new climate control box go never tackled anything like this before
thanks for helping much appreciated
Old Jun 26, 2015 | 03:33 PM
x_type_lpg's Avatar
there are two plugs for the climate control one white and the other black they both go to the RCCM module.
the plug from the radio needs to be plugged into the n ew radio unit that is part of the touchscreen lump
the aerial plug needs to be transfered as does the optical cable
the touch screen will have a new plug to the rear dvd unit.
pm me and I'll send you photos of the units and plugs
Amberlinder541
Sep 26, 2015 01:10 PM
mrsteady
Sep 20, 2015 03:38 PM
Samheath100
Sep 20, 2015 08:21 AM
texaspete
Sep 10, 2015 08:34 AM
Mike Green
Sep 7, 2015 12:39 AM
