Screen washer not working
Old Jul 23, 2015 | 06:16 PM
Paul M P's Avatar
Default Screen washer not working
Guys any ideas the screen washer and side light washer is not working I can here the pump working and the wipers move across the screen but no washer water comes out of the washer jets ho the resivoir is full .
Any ideas how I can fix Thanks forgot to say 2.2 diesel X type 2007
Old Jul 24, 2015 | 02:22 AM
Paul M P's Avatar
Smile
Guys managed to get working this morning took the pipe of that goes to the first washer jet operated the washer motor water came out re connected now all fine can only think could be air ? All works .
Old Jul 24, 2015 | 02:23 AM
mjtemple's Avatar
Could be a blocked filter, the filter is rubber and a part of the sealing grommet the pump pushes into at the bottom of the washer bottle. You access it from the wheel arch, there are 3 screws bolts holding the liner in place at the bottom, remove these and lift the liner up, pull out the pump and then the grommet/filter and clean the filter.
The filter looks like this.
Old Jul 24, 2015 | 02:32 AM
Paul M P's Avatar
MJTemple thanks for the reply and going to the effort of sending a Photo if it happens again I will investigate the blocked filter and thanks for explaining how to get to the part .
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
tberg
Sep 7, 2015 07:32 AM
philwarner
Sep 5, 2015 10:05 AM
