seat belt latch
Old Jan 26, 2021 | 02:54 PM
iownme's Avatar
Default seat belt latch
my driver side (U.S) seatbelt latch has stopped accepting the seatbelt.
The belt buckle wont push down into it and the latch inside looks different from the working one.
I bought a replacement but it looks like the seat needs to come out to install it.
Is this so, and is the old latch possibly fixable in place?
thanks
Old Jan 27, 2021 | 12:29 PM
avern1's Avatar
You will have to remove the seat rail fasteners and position the seat to reach the fastener holding the seat belt latch in position. Plus you will need to access the module under the seat to plug in the new seat belt latch. When I replaced mine I didn't remove the seat from the vehicle. I just rolled it around for access.
Old Jan 27, 2021 | 02:10 PM
iownme's Avatar
thanks avern1
will update when done
Old Jan 28, 2021 | 06:35 AM
DAVESPACEBAT's Avatar
If you have another anyway, it may be worth using a steel rule or a blade and split the plastic open while in place. The same fault happened to me, so I split the plastic cover open and found a sweet wrapper inside, which was jamming the mechanism. I took it out and re-glued the cover. Worked ever since.
Old Jan 28, 2021 | 12:54 PM
iownme's Avatar
thanks davespacebat, i'll give that a try
Old Feb 1, 2021 | 06:24 AM
iownme's Avatar
after trying to open the plastic housing with a large screwdriver, i must have dislodged whatever was causing the issue as its now working.
that was an easy fix
lol
thanks all
bigdiver
Apr 9, 2018 01:49 AM
kenatofc
Apr 5, 2018 09:21 PM
JPaul68
May 3, 2017 06:50 AM
JPaul68
May 2, 2017 02:47 PM
grantorino62
Oct 6, 2016 09:20 AM
