sensor code P1647
Old May 26, 2014 | 07:56 AM
rayclark1's Avatar
Default sensor code P1647
Anyone tell me which lambda sensor for the following code
linear 02 sensor control chip bank 02 ?
it needs changing but is it MAF - petrol or Oxygen lambda ?
Old Jun 1, 2014 | 05:15 PM
FMT's Avatar
FMT
Default 1647
upstream oxygen sensor
Old Jun 1, 2014 | 08:10 PM
emaraszek's Avatar
Upstream oxygen sensor (gray plug) near the radiator, which is bank 2
Old Jun 2, 2014 | 12:33 PM
FMT's Avatar
FMT
Default p1647
Yes, if your engine in transvers (sideways) it is the one near the radiator (Bank one is where your cylinder number one is located and bank 2 is the other side). It is the one before the converter, you might have to remove the water bottle. Spray a lubricant (wd40), let it soak a couple of minutes, use a 7/8" wrench (preferably a oxygen sensor wrench 7/8). Disconnect the grey plug first, then try to tighten the sensor a little, then break it loose and should come out with ease. Simply install the new one and your car is ready!
Good luck
Frank
Steviedee1st
Nov 28, 2023 06:32 PM
Shawn Svacha
Feb 6, 2022 04:53 PM
caveforce
38
Nov 16, 2015 10:19 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
joesoap
Sep 10, 2015 01:09 AM
