Shifting again.
Old Jul 26, 2017 | 11:46 PM
Spikepaga's Avatar
Default Shifting again.
Hello everyone !
I am once again concerned about my cars shifting. I have changed the transmission fluid multiple times, and I can NEVER replicate this when I test drive the car.
Sometimes (now 3 times in about 2 months) the car will shift hard from first to second. It's usually in stop and go traffic and it's when I am barely pressing the accelerator, letting go of the pedal and then softly hitting again to move forward. It's a hard shift. Maybe a jerk. Not that it slips in that the RMP's go up and the car won't go, but more like it jolts into second. I am hoping all it is is me hitting the accelerator at just the right time, but maybe there are some steps I should be taking to prevent a failure: changing solenoids maybe? Maybe a new TPS? Keep in in Sport mode or no? Should I start saving for a new transmission?.....usually the car is smooth and I can't feel it shifting no matter how many times I tried to duplicate the same scenario in a empty lot and different speeds. Any help welcome
Old Jul 27, 2017 | 05:29 AM
JagV8's Avatar
At least check the battery is excellent and then only if it is check fuel trims as a small air leak can cause mayhem.
Old Jul 27, 2017 | 05:30 AM
Namo's Avatar
Originally Posted by Spikepaga
Hello everyone !
I am having the same problem. When shifting from 1 to 2 i feel something like a little jerk. This is my 2nd transmission in this car. I hope its not a bad sign.
Old Jul 27, 2017 | 06:50 AM
Spikepaga's Avatar
yes. New battery and cables went in the first week after the car was delivered.
I have no lights on. My OBD2 reader shows my fuel pressure from 54-56. I am not sure how to check fuel trims though
Old Jul 27, 2017 | 06:53 AM
Spikepaga's Avatar
I hope not. Is it always happening? I am leaning towards a new TPS/throttle body based on my experiences with my other X type, but that's a 600 dollar experiment.
Old Jul 27, 2017 | 06:58 AM
Namo's Avatar
It does not always happen, Checked it out and discovered my driver side shaft that goes into the gear box is a bit loose. Will need to change the shaft entirely and hope it solves it.
Old Jul 27, 2017 | 07:05 AM
Spikepaga's Avatar
I dont know that that would cause a hard shift though.
How hard is it to access the valve body, I wonder. I Maybe new solenoids ? If it's not cost prohibitive to replace the 1-2 and 2-3 solenoids I would like to have that done.
its such a pain to have to baby the accelerator to prevent a hard shift or a jolt
Old Jul 27, 2017 | 11:55 AM
JagV8's Avatar
Use the site's Search.
Or a web search if you want yet more detail.
