Should my boot lift itself up?
Old Jan 31, 2016 | 04:32 PM
otherman's Avatar
Default Should my boot lift itself up?
Hi all,
just picked my 2.5 AWD and I'm pretty pleased with it. One question - on my S type, if I used the remote boot release, the boot would spring open. On the X type it unlocks, but then needs lifting up. Is that normal, or is there a gas strut defiency here?
thanks
Old Jan 31, 2016 | 06:00 PM
santer's Avatar
Usually open an inch or so, just to clear the lock, if yours does not move at all then there are these
Search results for: 'x type jaguar'
This was planned but did not work as hoped
Jaguar X-Type auto boot open
Old Feb 1, 2016 | 01:50 PM
otherman's Avatar
Very interesting, thankyou. If a little dissapointing.
It seems we think that stronger gas struts would make it too hard to close, and yet the S Type does open itself using only the struts. I can't imagine the boot is so much lighter, but some research there is called for. I'll try and get myself next to one and compare.
Old Feb 1, 2016 | 06:13 PM
hlgeorge's Avatar
I would press the trunk(boot) opener and the lid would not even open enough past the secondary position. I had to lift the lid while I was pressing the remote. I discovered I had the missing "trunk poppers" on the hinges. I replaced the poppers and a drop of oil on the hinges solved the problem. The lid doesn't open all the way up, but I don't like that when it is raining.
Old Jun 19, 2021 | 02:51 PM
cjwaywell's Avatar
Default Easy Fix
Originally Posted by otherman
Hi all,
thanks
You put a 600N damper on one side and a 20mm spring this then lifts the boot about a foot. If you put 2 dampers and 2 springs on it will lift it all the way but it opens fast and shakes the boot a bit and probably weakens the hinges. Having it open about a foot is about right for me.
Stuart@VelocityAP
Jun 29, 2017 01:39 PM
hardwired
Feb 24, 2016 09:13 AM
gmcgann
Jan 28, 2016 12:12 AM
stingray71
Jan 27, 2016 10:18 AM
Brian BigSkip Skipper
Jan 27, 2016 02:35 AM
