sounds like a sqweeky bed???
Old Jan 29, 2008 | 06:22 AM
FactoryJaguarTech's Avatar
Default RE: sounds like a sweeky bed???
Peewee read upward. Lube your park brake cables. They dry out in the heat and squeek.
Old Jan 30, 2008 | 11:38 AM
jvegas's Avatar
mine is the shock for sure. i checked the cable and it seems fine. i will lube it anyways after reading what everyone says on this post.
Old Feb 3, 2008 | 01:56 AM
jvegas's Avatar
ok, so it was NOT the shock. the car feels better but that damn sound is still there! I lubed the cable but still there! I am going to jack the car up and check EVERYTHING! I will update you all once i find the frickin noise..
Old Feb 3, 2008 | 03:00 AM
Cadillac's Avatar
good luck with your finding
Old Feb 3, 2008 | 09:48 AM
Spray lube the rear hub carrier bushings. Also the rear brake pads have been known to squeek like that. Especially if they were installed upside down [8/|]
Old Feb 3, 2008 | 10:59 AM
jvegas's Avatar
i though maybe the breaks but when i have the hand brake on it still makes that sound. i will try having some one hold doen the foot brakes while i bounce the car up and down.... i hate this sound it is making i wish i knew how to make a sound clip so you could hear it. will update later tonight.
Old Feb 4, 2008 | 12:12 AM
  #28
jvegas's Avatar
UPDATE: I took the car to a friend’s house and we jacked up the car in the 30 degree weather. We sprayed every and all bushings, bearings, and damn near all bolts in the rear of the car. We set the car back down and still made the damn sound. So we jacked her back up, took off the rear passenger tire (that is where the sound is coming from) and sprayed the top of the new shock I just had installed. The sound went away! After about 2 minutes of driving it came back so next week we are going to shoot some grease up there thinking it will last longer and hopefully make the sound go away for a long time. I wish I had a lift so I could get a better look at it but I guess I will just do what I can. I think there is a bushing on the top of the shock I might be able to replace but I did not see one.
Old Feb 4, 2008 | 05:03 AM
If it is the shock you just had replaced, take it back and have them fix for free.
Just explain what you did to correct it so they know where to look.
Old Feb 4, 2008 | 09:56 AM
  #30
jvegas's Avatar
is there some type of rubber bushing on the top of the shock?
Old Feb 4, 2008 | 07:00 PM
  #31
not on the x-type rear. Held on with 2 10mm nuts at top and I think 21mm bolt at bottom. Just a regular shock. Not a strut.
Old Feb 4, 2008 | 11:17 PM
  #32
jvegas's Avatar
the temp went up to 50-60 today. the sound went away?!? what the hell is that? i will check it tomorrow and see but could the cold do something to the shocks or bushings?
Old Feb 5, 2008 | 06:23 PM
  #33
I still dont think it is your shocks. Chances of you putting new shock in and noise still being there is pretty slim.
Lube the white plastic bushings in the rear hub carrier with a lithium or white grease.
Have you changed your brake pads in the rear?
Old Feb 5, 2008 | 09:36 PM
  #34
housegroove77's Avatar
its strange, that they replaced a shock because they assumed thats the issue but it wasnt? i say go back and ask them to check out what the wonderful people here on this board think it may be.
Old Feb 5, 2008 | 10:24 PM
  #35
aquill1's Avatar
Noises are hard sometimes...shoot belle tire told me everything in the front end of a thunderbird I had was bad...700-800 dollars worth of parts later the only 2 things they never said were bad were the bad things! The upper control arms were bad on both sides and that was only 40 bucks brand new! The upper control arm houses the ball joint as well! Needless to say my knuckles, back, wallet and head were not too happy! What can I say though I had them diagnose and than I fixed it! Oh well live and learn!
Old Feb 5, 2008 | 10:50 PM
  #36
jvegas's Avatar
i would go back but when you are under the car it sounds like it is the shock. If they did not put a new one in I would have had them do it anyways because it is makeing the noise from that area. Like i said it warmed up here a bit (35-50 degrees) and the sound is gone. plus the car does drive a little bit better.
Old Feb 6, 2008 | 06:04 AM
  #37
But the noise still lurks.
Hope it stays gone for you.......but it won't. Noises tend to notfix themselves.
Old Feb 6, 2008 | 09:58 PM
  #38
jvegas's Avatar
damn it is back!
Old May 14, 2008 | 09:11 PM
  #39
mobiledave's Avatar
Bump... Im having the same problem??
Jvegas what did you do?
Old Jun 16, 2008 | 02:46 AM
  #40
peewee's Avatar
Mine did the same thing. They only made noise when it was warm out not cold. I thought it was due to crappy interior plastics. I will try lubing the parking cables and WD40 the suspension components to see if that makes a difference. I cant live with the damn noise anymore.
