sounds like a sqweeky bed???
Old Jan 25, 2008 | 12:57 PM
jvegas's Avatar
Default sounds like a sqweeky bed???
I was driving my x-type the other day and noticed a sweeky sound coming from the rear of the car. I got out of the car and when I push down on the back of the car you can hear a sweeky sound from both rear wheels. It sounds like from the suspenion. I thought mabey a bad shock but, from both sides at the same time? Has anyone heard of this or knows what it may be?
Old Jan 25, 2008 | 01:02 PM
Dennis's Avatar
ud
Default RE: sounds like a sweeky bed???
I think it maybe some squeaks coming form some of the suspension bushings, etc...are you in a real salty climate right now?..Maybe a good undercarriage wash may help..I'm just guessing it's nothing serious.
Old Jan 25, 2008 | 05:16 PM
jvegas's Avatar
i am in a salty area. I got the car washed and it did not help. I will take it to a better wash tomorrow. is this a common thing to have happen? Before this sound came about I did hear a small "chip" when driving. So think they are related?
Old Jan 25, 2008 | 05:59 PM
Humy's Avatar
WD40 the shocks and springs back there
Old Jan 25, 2008 | 06:19 PM
FactoryJaguarTech's Avatar
If you have an X-type and it is making that noise, first thing I would do is look at the nylon bushing on the rear hub carrier where the parking brake cables go through. Put some grease on either side of the cable and pull it back and forth through the bushing so it is lubricated. Then see if the noise is gone.
That squeek is very common.
Old Jan 25, 2008 | 06:44 PM
jag_genius's Avatar
that squeek usually is when driving.. if the noise is a loud squeek then it cud be the lower control arm bushings in the rear .. get very noisy.. small tubular 8 inch black piece.
Old Jan 25, 2008 | 10:30 PM
jvegas's Avatar
i got the under body washed real good. it still makes the sweek. I have noticed in the past a thump sound after hitting a bump. It is just a sound, you don't feel it.. just hear it. It almost sounds like there is something in the trunk thumping. I cleared out the trunk, tire and all yet the sound was still there and is still there. I wonder if that has something to due with the sweek I now have. Any thoughts?
Old Jan 26, 2008 | 07:04 AM
Like Genius said, the thump could be the sway bar bushings. Only takes 5 minutes to change them.
The squeek however I am convinced may be the parking brake cables. There is a tsb for that.
I have also seen the rear shocks thump when they go bad.
Old Jan 26, 2008 | 05:33 PM
jvegas's Avatar
I went and had the car checked today. They found out it is a bad rear shock. They ordered a new one for me and I am having it put in on Monday. Juat so you know...
Old Jan 26, 2008 | 06:18 PM
Dennis's Avatar
ud
Good to know..thanks for the up-date..I wish more people would come back and tell us what the problem was, once it was fixed..
Old Jan 26, 2008 | 06:47 PM
Good to hear.
Did you also have them lube the parking cables?
Old Jan 26, 2008 | 09:55 PM
aquill1's Avatar
My shocks have the same problem vegas. Both sides squeak, except when its cold out. My rear suspension has made noises at times for a while...
How much for the fix? Parts are 120 per shock from the dealer...
Old Jan 27, 2008 | 05:28 AM
Cadillac's Avatar
I must admit that the thread title is so funny
Old Jan 27, 2008 | 11:34 AM
jvegas's Avatar
The price will be $200 for parts and labor. good-bad?
Old Jan 27, 2008 | 09:48 PM
jasonzimbran's Avatar
Same here when I hit a bump I hear something squeky in the rear. I thought it was the spare But I was wrong.
Old Jan 27, 2008 | 09:53 PM
Dennis's Avatar
ud
ORIGINAL: FactoryJaguarTech
Good to hear.
I for one have..I did it when I had it up in the air for the Brake job I did about 6 months ago..Good tip FJT
Old Jan 27, 2008 | 10:20 PM
jvegas's Avatar
so is $200 for parts and labor a good price or a not so good price?
Old Jan 28, 2008 | 04:23 PM
housegroove77's Avatar
Jvegas,
and are the only replacing one shock for $200? For both i think it is a good price!!! i hope my squeeking is the same issue as yours (mine only when its warm and over sleeping policemen or big bumps).
Old Jan 28, 2008 | 09:47 PM
jvegas's Avatar
no thats just for one. the shock cost over $100 each. that would mean free labor if i had them both done for $200.
Old Jan 29, 2008 | 03:02 AM
peewee's Avatar
Mine makes that DAMN squeaking sound too! Its not the shocks, or the doors its just the shitty build materials. During the summer the car squeaks during the winter its all quiet. I think the plastics expand and contract varying on temp and this causes them to loose integrity and squeak.
I had an older (98) camaro ss that is KNOWN for its squeaks and rattles and that thing road like a tank compared the the jag. On occasion the trunk hatch in my camaro would squeak. In the jag if i hit an ant hill my car chirps. Like i said it only does this when its warm like the summer and not in the winter. If it was the shocks I would think that it would continue regardless. If its the plastics on the interior of the car or other body panels that are more likely to be effected by the degrees in varying temps then it would explain why it squeaks rattles and rolls during the summer and not during the winter.
